Re: Carb Choice Street Engine 440
[Re: Roughbird72]
#1483640
08/13/13 09:53 AM
08/13/13 09:53 AM
Posts: 3,813 Arlington, Texas
bobby66
Arlington, Texas
the Holley 3310(750 vac.) would also be a good carb for a street 440
Or this. Pretty much the default carb for street hot rods.
[Re: domingo]
#1483643
08/13/13 10:11 AM
08/13/13 10:11 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Thanks for the advice. I will go with the brock 800 avs then.
Now on another note, I want to add a complete MSD ignition system.
What distributor and what ignition box would you use with this engine? opinions?
Try getting a Firecore dist and see if you can get a 6-al ignition... might try the Firecore coil also JMO
[Re: fbernard]
#1483645
08/13/13 11:22 PM
08/13/13 11:22 PM
Posts: 4,027 Dearborn Hts, MI
Sledge_57
Dearborn Hts, MI
Street engine? Whatever you pick, take a distributor with vacuum advance.
I use MSD Pro Billet, 6Al and Blaster(2?) coil. No vacuum advance, lightest springs and whichever bushing gave the most initial advance, worked great, putting same setup in my 383...
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
[Re: 340SHORTY]
#1483651
08/16/13 10:16 AM
08/16/13 10:16 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
IF you could find a good 1..
Go for the gusto, put 3 Holley 2300s on it..
Plenty of TQ's around, lack of strip kits are the issue for the average consumer. I just drill out or modify my own stuff.
