72 Challenger Sunroof #1482762
08/11/13 12:49 PM
08/11/13 12:49 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Ran across a 72 challenger today with a sunroof. Anyone know the numbers on how many were produced M51 Option
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: 72 Challenger Sunroof [Re: 19cuda73] #1482763
08/11/13 10:52 PM
08/11/13 10:52 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Here is a shot of the sunroof. He says it was a vinyl top car before the repaint.
1972 Corvette
Re: 72 Challenger Sunroof [Re: 19cuda73] #1482764
07/21/14 08:05 AM
07/21/14 08:05 AM
Rapid City, SD
sdweatherman Offline
Rapid City, SD
Currently putting together some numbers for the later E-body power sunroof cars. This is a very preliminary number - but easily less than 200 base Challengers and Challenger Rallyes combined. Probably closer to 150 combined. I have seen other estimates as low as 30,(and that may be just for Rallyes), but I have reason to believe otherwise. I need to document several more before I can give a more accurate production number for these cool cars.
Scott.
1971 GY8 SSP 318/Auto
1971 GB7 SSP 318/Auto factory Sunroof
1972 EV2 SSP 400HP Loaded w factory Sunroof
Re: 72 Challenger Sunroof [Re: sdweatherman] #1482765
07/21/14 10:05 AM
07/21/14 10:05 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I can account for two Plymouths, a 72 GTX and 72 Cuda. I would like to find a pair of Dodge's. Production numbers seem to be all over the map. Don't know who to believe. I would like to hear more about them really.
Re: 72 Challenger Sunroof [Re: scatpacktom] #1482766
07/21/14 12:45 PM
07/21/14 12:45 PM
Rapid City, SD
Rapid City, SD
Hey Tom,
Great pair you have there. I ran across your thread on the RRGTX, but had not run across your 72 Cuda yet. I have put together a couple of pamphlets on 71 and 72 Ply B-bodies that I have run across, and they are located here:
RRNest thread on 71-72 ply sunroof cars
Thanks for posting the info on your 72RRGTX!
Scott.
Re: 72 Challenger Sunroof [Re: sdweatherman] #1482767
07/22/14 11:59 AM
07/22/14 11:59 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Nice list Scott. Alot more 71s than 2s huh? Thanks for putting the list together.
I took the Cuda to Carlisle hoping I would find someone that may have remembered it or known of its history. Unfortunately I couldn't hang out with it much. For 25 years I've been roaming around car shows and while I know others are out there, this is the only Cuda with the sunroof option I have ever seen with my own eyes.
Sorry for the Hi-jack
Re: 72 Challenger Sunroof [Re: scatpacktom] #1482768
07/22/14 01:05 PM
07/22/14 01:05 PM
Farmington, CT
KISSAlien Offline
KISSAlien  Offline
Farmington, CT
I didn't know that was your car Tom. I did see it and took a few pics.
Re: 72 Challenger Sunroof [Re: scatpacktom] #1482769
07/22/14 09:27 PM
07/22/14 09:27 PM
Rapid City, SD
Rapid City, SD
Only a small Hi-jack - just expanding it to 72 sunroof E-bodies. I took another look at the few 72 Cudas/Barracudas that I have run across and can venture a very preliminary estimate. I have also seen a couple of forum posts that state GG numbers of 32 or 33 'Cudas that came with the factory sunroof. This seems reasonable, as my estimate for total 72 'Cuda/Barracuda production should be around 70-75 cars. That works out to about 40-ish BH23 cars with the sunroof. Very few and far between - which is why you don't see very many.
I have not ravaged the net for the 72 B-bodies as much as the 71's, so the list is not as extensive. But I do believe that production numbers for the 72's are a bit less than the 71's. In addition, the 71's are likely being sought-out and restored at a better clip than the 72's.
Scott.
