Front End Alignment Tech Needed #1482552
08/10/13 09:31 PM
08/10/13 09:31 PM
Sweet Home Alabama
MRMOPAR622 Offline OP
Sweet Home Alabama
The front end of our new Altered has the dragster tripod with Mark Williams spindles. The front end alignment looked off to me. I set the tow end from 5/8" to less than 1/16", that helped the handling some. Now for the problem, if you put a straight edge at the top of the wheel it is setting in 7/16" at the bottom on each side. What kind of problem would that cause besides tire wear? I was thinking of trying to make an off set bushing rolling it to the inside about 15 degrees to get the wheels straight up and down. Thanks
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Front End Alignment Tech Needed [Re: MRMOPAR622] #1482553
08/10/13 09:53 PM
08/10/13 09:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Is it a rigid or spring front end... I think I would
cut and weld either the upper or lower.. which ever
is the easiest... but get the camber to zero with
any where between 6* and 10* caster... on my car I
run 10* caster... drives like a caddy
EDIT
can you post up a pic of the front end
Re: Front End Alignment Tech Needed [Re: MR_P_BODY] #1482554
08/11/13 12:13 AM
08/11/13 12:13 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Sounds like the front end was welded on wrong. my altered has zero camber, 15* caster with 1/8 to 3/16ths toe
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Front End Alignment Tech Needed [Re: MRMOPAR622] #1482555
08/11/13 12:35 AM
08/11/13 12:35 AM
MR_P_BODY Offline
MR_P_BODY  Offline
This is a car I built for my brother... he wanted a
nostalgia altered.. its a straight axle with 12* caster,
0 camber and 0 toe in..and drives like a dream at
160 mph... a cheapo SBC with decent heads and a roller..
a solid rear suspension...125" wheel base.. I never
got into the nostalgia stuff myself
Re: Front End Alignment Tech Needed [Re: MRMOPAR622] #1482556
08/11/13 01:56 AM
08/11/13 01:56 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
Billy check to see if there is a top and bottom to the spindle some have a little offset in them and yours could be upside down
Re: Front End Alignment Tech Needed [Re: SB412DUSTER] #1482557
08/11/13 03:16 PM
08/11/13 03:16 PM
Sweet Home Alabama
Sweet Home Alabama
Thanks for the advice everyone. The spindle's do have 6 degrees built into them,but they are turned the right way.I should have said our used car,just a new car for us.It's a solid front-end,king pins bushings all check out good,don't understand how they got the same amount both sides that far off.Unless I can fab up some king of off-set bushing an pin it where it can-not move,looks like I may have to do some cutting & welding.That's no problem as I am a welder,but I don't have a front-end jig.Thanks again everyone for the help!
