New Distributor Question #1482501
08/10/13 07:36 PM
08/10/13 07:36 PM
Boca Raton, Florida
daveh1971 Offline OP
Boca Raton, Florida
Hey guys,
I'm thinking about getting the following distributor for my 340 Challenger what do you guys think?
What would be the pro & cons?
http://www.summitracing.com/parts/msd-8388
Re: New Distributor Question [Re: daveh1971] #1482502
08/10/13 09:09 PM
08/10/13 09:09 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
the con's,
The price and if you have a problem or suspected problem your up the creek especially if one is out of town on a long run.
Myself I like the factory stuff as it typically works as well and is easily serviced should a problem develop
The pro's??? None I can think of unless one is into the MSD BLING
Re: New Distributor Question [Re: TJP] #1482503
08/10/13 09:30 PM
08/10/13 09:30 PM
the con's,
I'd suggest using any 70's SB electronic dist & adjusting the subsystems in order: initial (vac gauge method)/total (35)/ springs (stay just under the pinging point at WOT)/vac adv (2 adjustments. The real bennie is going to come from the coil/ballast/no ballast selection. I'd suggest a "Dynamod" HEI module mounted under the dist (to hide it) & an E coil & no ballast. You have many ways to go on your choice there
