I was planning to go in this:
But I didnt get it done in time.
So now I'm riding shotgun again (Trunk Monkey) with Jay Brown.
We are taking his 69 Mach I, with the 545"FE highriser wedge. The motor is areally cool build with a ton of home made parts.
You can see Jays engine build on his website here:
http://fepower.net/simplemachinesforum/index.php?topic=168.0Here is the Mach I in action:
We should be running in Big block naturaly aspirated street race. The cars biggest limitation is traction. It is a real R-code (428 Cobra Jet) Mach I, so jay isn't willing to cut up the body to fit bigger tires. And he wants to stick with a stock appearing theme as much as possible, so nothing has been done to lighten it. We will be leaving for Drag Week with this combo mostly untested.
I need to make sure and meet up with all you fellow Mopar lovin'Drag Week guys, even though I'll be in a Ford.
