welding up slots in advance weights #1481913
08/09/13 09:24 AM
08/09/13 09:24 AM
Frederiction. New Brunswick ,C...
RTshaker Offline OP
RTshaker  Offline OP
OEM electronic. What are the issues of brazing up the slot limit on ONE weight and not the other side ? I have erratic {bouncing }timing on my light at full advance weight 34-36 . ?
Re: welding up slots in advance weights [Re: RTshaker] #1481914
08/09/13 09:32 AM
08/09/13 09:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Does it advance the amount you need... sounds like
the intermediate shaft and dist shaft are lifting
and dropping... a 1/2" collet on the dist shaft to control
the end play should fix it
Re: welding up slots in advance weights [Re: MR_P_BODY] #1481915
08/09/13 11:27 AM
08/09/13 11:27 AM
RTshaker Offline OP
RTshaker  Offline OP
Small block .Advances to 36 ,then upon holding at ~3000 rpm ,then starts to jump around34-36 . I have the collar mentioned on my BB . I`ll have to try it on the SB .I was just curious as to the brazed slots ,I had heard others say to braze both weights but I couldn`t see why it would matter except for better distribution of load /wear ??..Thanks
Re: welding up slots in advance weights [Re: RTshaker] #1481916
08/09/13 12:09 PM
08/09/13 12:09 PM
I weld up both sides the same length, I measure with them with a set of dial calipers I use a small rotary file on a dremel to get them even
Re: welding up slots in advance weights [Re: RTshaker] #1481917
08/09/13 12:11 PM
08/09/13 12:11 PM
ill
dennismopar73 Offline
ill
What ever it takes to lock it down very hard to keep a dixxy with springs settled.
put nut bolt weld zip tie ,
Re: welding up slots in advance weights [Re: dennismopar73] #1481918
08/09/13 07:43 PM
08/09/13 07:43 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Have you checked the distributor tang is fairly tight in the pump gear. I've put the distributor shaft across the back of a vice and given it a light rap with a hammer to make it more snug.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: welding up slots in advance weights [Re: RTshaker] #1481919
08/09/13 08:02 PM
08/09/13 08:02 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Heavy spring(s) will do that
