Re: welding up slots in advance weights
[Re: RTshaker]
#1481914
08/09/13 09:32 AM
08/09/13 09:32 AM
Posts: 52,972 Romeo MI
MR_P_BODY
OEM electronic. What are the issues of brazing up the slot limit on ONE weight and not the other side ? I have erratic {bouncing }timing on my light at full advance weight 34-36 . ?
Does it advance the amount you need... sounds like the intermediate shaft and dist shaft are lifting and dropping... a 1/2" collet on the dist shaft to control the end play should fix it
[Re: MR_P_BODY]
#1481915
08/09/13 11:27 AM
08/09/13 11:27 AM
Posts: 330 Frederiction. New Brunswick ,C...
RTshaker
Small block .Advances to 36 ,then upon holding at ~3000 rpm ,then starts to jump around34-36 . I have the collar mentioned on my BB . I`ll have to try it on the SB .I was just curious as to the brazed slots ,I had heard others say to braze both weights but I couldn`t see why it would matter except for better distribution of load /wear ??..Thanks
[Re: dennismopar73]
#1481918
08/09/13 07:43 PM
08/09/13 07:43 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Have you checked the distributor tang is fairly tight in the pump gear. I've put the distributor shaft across the back of a vice and given it a light rap with a hammer to make it more snug. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
