74 model 8 3/4 truck rear wheel stud knurl diameter.
#1481744
08/08/13 08:32 PM
08/08/13 08:32 PM
Posts: 1,652 Amarillo, Tx
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
I am getting conflicting results from different suppliers. Wanting longer than stock studs.
84 D150 440/727 79 /6 swb D150 1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: 74 model 8 3/4 truck rear wheel stud knurl diameter.
[Re: old_goat]
#1481745
08/08/13 09:34 PM
08/08/13 09:34 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
This is Dr Diffs answer to the same question I asked him awhile ago.. I don't stock press-in wheel studs, but these are the rear version I order when I need them: http://www.summitracing.com/parts/MRG-4311/ All other brands don't fit Mopar axles correctly. If the truck rotors share the same knurl size as the cars, these should fit: http://www.summitracing.com/parts/MOR-46180/ Be sure to use anti-seize on the threads.
I am truckless..
