Re: 1970 426 Hemi Correct Intake Manifold hardware question
[Re: joeblow]
#1480995
08/07/13 01:23 PM
08/07/13 01:23 PM
Posts: 2,678 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I'm not fresh on this. I think you will see it when you put the intake on. I believe it goes in the tallest boss on the intake, up front where the small throttle return spring bracket goes. Sorry I can't be totally sure. It has been awhile I guess.
2011 Drag Pak Challenger
[Re: rickseeman]
#1480996
08/07/13 01:43 PM
08/07/13 01:43 PM
Posts: 10 Kyle, Tx
joeblow
Kyle, Tx
I didn't get any instructions as to where these Bolts/studs should go. You'd think for 145 bux you'd get a color 8x10 glossy photo. And there's no single Boss on the Intake that's taller than the rest of'em. If I were a betting man, I would guess that it would go into the hole that the spring bracket, and the Spark Plug wire retainer share on the front left side of the intake as you suggested, but this stud is quite a bit taller than the rest. Can anyone confirm this, or set me straight ?
