Page 2 of 3 1 2 3
Re: noisy comp lifters [Re: Commando1] #1480919
08/07/13 09:35 PM
08/07/13 09:35 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
XE cams are aggressive on the ramp and do sound noisey.
MLR426
X2
End of story. Nothing you can do about it.
X3
Reset the pre-load about have a dozen times on my XE275HL. I'm running Topline Johnson lifters (R-series IIRC). I can make it louder, but I can't make it quiet. Pretty much the nature of the beast.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: noisy comp lifters [Re: 471Magnum] #1480920
08/08/13 12:57 PM
08/08/13 12:57 PM
North Austin
KnuckleDuster Offline
North Austin
x4...
XE285HL
Comp pro Magnum rockers
Crane anti-pump up lifters
Been through the valves twice already trying to quiet it down, gonna go through once more hot and call it a day. Judging by the amount of noise thought maybe I did too little preload and had a pushrods bouncing off the rockers...???
Re: noisy comp lifters [Re: KnuckleDuster] #1480921
08/08/13 03:12 PM
08/08/13 03:12 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
x5
With all the clatter and messing around trying to adjust them, I don't see what the point of the big hydraulic cams is, might as well have a solid and make more power all other things being equal.
One thing I wish I would've done different with my 440.
Re: noisy comp lifters [Re: 67Satty] #1480922
08/08/13 03:51 PM
08/08/13 03:51 PM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
hum... seems like the next 440 will have to have a roller...
Re: noisy comp lifters [Re: mopfried] #1480923
08/08/13 04:18 PM
08/08/13 04:18 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What is the big issue , are we all spoiled by how quiet our Prius is?
easy enough to fix , put in a cam with a chevy lobe like we only used to have in the past , problem solved
I don't understand why someone would go to the expense of installing an adjustable valvetrain on a hyd. cam ???
Re: noisy comp lifters [Re: JohnRR] #1480924
08/08/13 07:13 PM
08/08/13 07:13 PM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
My heads are cut .100 to make 452 heads closed chamber. I have access to machinery... or I did. Im to cheap to replace pistons and deck the block. I do it cause they say it cant be done. I also made my own cut to fit push rods. It just sounds like the oil pump is bad when you rev it up and the lifters rattle... I guess I can tell the chevy guys my cam is wiped while they see my tial lights and smell my tires.
Re: noisy comp lifters [Re: mopfried] #1480925
08/08/13 07:53 PM
08/08/13 07:53 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
I have a XE275 and mine is noisy too. I've adjusted my valves once since the motor was put together and they really didn't even need it. I've heard many people say they are just noisy cams.
Re: noisy comp lifters [Re: 67Satty] #1480926
08/08/13 08:38 PM
08/08/13 08:38 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
x5
Agreed. Not to mention the quality issues with hydraulic lifters available today. So, faster ramps than ever, the need for much more spring pressure for control, and poor quality lifters that are generally more complicated. I doubt many are getting the performance out of their fast ramp cam profiles that they should. If you really care about performance, put a solid in it. Otherwise, put a lolli-pop cam in it, close the hood and forget about it.
I must really be the odd one out here. To me there is nothing sweeter than the sound of solids, and nothing say performance better.
Re: noisy comp lifters [Re: BSB67] #1480927
08/08/13 09:06 PM
08/08/13 09:06 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I have a big hyd cam from straightline performance and I just replaced my lifters with a set from Comp cams. I was shocked that they just wanted the lash set from 0 to 1/8 of a turn as normally I would go to a 1/2 turn. Anyway I was surprised that they were as quiet as they were. Maybe it's because I am running M/T cast aluminum valve covers. (Very thick compared to some valve covers which may stifle the noise)
Re: noisy comp lifters [Re: rapom] #1480928
08/08/13 09:26 PM
08/08/13 09:26 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
It depends on the lobes. Some of the Straightline performance stuff I have seen has very gentle ramps.
Re: noisy comp lifters [Re: BSB67] #1480929
08/09/13 12:41 AM
08/09/13 12:41 AM
IN
ahy Offline
ahy  Offline
IN
x5
Me too. A little sewing machine sound is nice... the sound of power.
Re: noisy comp lifters [Re: JohnRR] #1480930
08/09/13 02:44 AM
08/09/13 02:44 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Come on.. a SMART guy like you asks this?
The guys at Comp suggest an adjustable valvetrain to achieve preload. With my limited cam knowledge, I can see how that having each rocker adjusted to a specific setting compared to being along for the ride on a common shaft....Makes sense to me.
Re: noisy comp lifters [Re: BSB67] #1480931
08/09/13 10:21 AM
08/09/13 10:21 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You are not alone.
Re: noisy comp lifters [Re: Kern Dog] #1480932
08/09/13 10:27 AM
08/09/13 10:27 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
True but if you are going to buy adjustable rocker you might as well get a solid cam for max performance ... and if I remember correctly aren't you switching to a solid cam ??? You could have saved a bunch of money and just bought one in the first place.
Re: noisy comp lifters [Re: JohnRR] #1480933
08/09/13 05:06 PM
08/09/13 05:06 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
John, you are always an asset here and I have learned to rarely question your advice. I'm not arguing with you here, just an alternative perspective.
I ran the stock rockers even with a Comp .545 cam and later developed valve stem wear. After reading online tech stuff, I stumbled upon Comp's advice about running adjustable valvetrain to achieve preload. I've since read that my valve stem wear could have been due to rocker geometry, rocker tip misalignment, etc.
My changes to my 440/493 are part of an ongoing improvement and learning process. I have no doubt that this engine is serving as an 8 cylinder set of "training wheels" and that my next build will greatly benefit from the lessons I have learned.
MANY of the members here are to be credited for helping me with it all.
Re: noisy comp lifters [Re: ] #1480934
08/09/13 05:16 PM
08/09/13 05:16 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Nothing you can do that series of cams clatter--I think closing ramps are the culprit.
This. I had the 275 and same thing. My solid .557 MP loose lash cam is quieter!
Re: noisy comp lifters [Re: ahy] #1480935
08/09/13 05:21 PM
08/09/13 05:21 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
x5
Sounds like some guys spend more time adjusting valves on their big hydraulic flat tappets than I spent with my solid roller.If you're gonna run a big cam like that..might as well do a solid. I run the valves on mine in the spring(about 20 min tops) put the covers on and drive it all summer. The tight lash solids aren't even that loud...
Re: noisy comp lifters [Re: rapom] #1480936
08/09/13 06:09 PM
08/09/13 06:09 PM
Annapolis, Md
71TrakPak Offline
71TrakPak  Offline
Annapolis, Md
Which set of lifters did you buy??? the Pro Magnum set are higher RPM lifters and require adjustable rockers w/ little to no lash as stated above. They are as close to a solid lift as you can get in a hydraulic. The "street" or lower rpm model may take the usual 1/2 or more turn. Verify which lifter set you have. Some of the lifter models do state noisy valve train as a side effect.
Good luck
1971 Charger R/T 4spd
Re: noisy comp lifters [Re: Dcuda69] #1480937
08/09/13 10:16 PM
08/09/13 10:16 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
x5
Same here I adjusted them once on the test stand and once after about 5 passes three years ago.My valve train is pretty bulletproof though with bushed Isky iron rockers.
My XE HL Comp hydraulic was more annoying than the solid Comp I have in the Savoy now.I run it very tight though 12 intake and 14 exhaust cold.
Gus
64 Plymouth Savoy
Dana 60
Re: noisy comp lifters [Re: fourgearsavoy] #1480938
08/10/13 01:33 PM
08/10/13 01:33 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
This is some shocking news! A noisy comp xe hyd cam? Really?? Sorry couldn't help it. It's not the lifters,it has nothing to do with .904 lobes or anything except the closing ramp,or lack of. Usually when this issue comes up hasn't it always been the lifters? adjustment? or some mystery? seems like it to me. You can get a great hyd(sounds all wrong to me too.LOL) camshaft that won't wear out the nerves from Tim @ Bullet cams.
Page 2 of 3 1 2 3
