4.2 KICKDOWN LEVER...AS OPPOSED TO THE 5.0? #1478920
08/03/13 04:29 PM
08/03/13 04:29 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
I'm having my 727 freshened-up..after 11 yrs. of abuse in my street/strip '69' GTX. I run a Turbo-Action Cheetah valve body,and a bolt-in sprag. It was recommended that I install a Heavy Duty Strut..HD Retainer,and a 4.2 lever,to replace the 5.0 that's in it now. Any thoughts on this modification...good or bad? I trust the builder wholeheartedly...just want some opinions about the lever...and why,EITHER WAY! Thanks in advance! Randy B.
Re: 4.2 KICKDOWN LEVER...AS OPPOSED TO THE 5.0? [Re: Labratt] #1478921
08/03/13 04:33 PM
08/03/13 04:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The 4.2 is favored over the 5.0 and HD components are always a wise investment.
Re: 4.2 KICKDOWN LEVER...AS OPPOSED TO THE 5.0? [Re: Labratt] #1478922
08/03/13 08:59 PM
08/03/13 08:59 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
When I had Pro-trans freshen up my trans 12 years ago, it had the 5.0 lever and the screen filter and when I got it back in had the 4.2 lever and a stock filter.............
Re: 4.2 KICKDOWN LEVER...AS OPPOSED TO THE 5.0? [Re: Labratt] #1478923
08/03/13 10:18 PM
08/03/13 10:18 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
As I remember the old school thinking was that the extra leverage of the 5.0 was better.
But as it turned out the extra leverage wasnt needed and the Slower reaction of the 5.0 was a hinderence. The 4.2 was a better comprimise of levarage and reaction. So the 4.2 is favored now.
Randy, good to see you posting again,
Re: 4.2 KICKDOWN LEVER...AS OPPOSED TO THE 5.0? [Re: Sport440] #1478924
08/04/13 03:27 AM
08/04/13 03:27 AM
Eugene, OR
FuryBoy Offline
FuryBoy  Offline
Eugene, OR
Just found an AA 4.2 levee in my parts stash going to replace the 5.0 when I put the deep pan on in a few weeks.
Re: 4.2 KICKDOWN LEVER...AS OPPOSED TO THE 5.0? [Re: FuryBoy] #1478925
08/04/13 02:46 PM
08/04/13 02:46 PM
crisfield, maryland 21817
8
82ramIndy493 Offline
You better allow extra time as you will have to pull the tranny and converter and valvebody to change that arm.
Re: 4.2 KICKDOWN LEVER...AS OPPOSED TO THE 5.0? [Re: Sport440] #1478926
08/04/13 06:21 PM
08/04/13 06:21 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks,Mike! I've been staying pretty busy for a while now! Piecing the GTX back together,and working 3 days a week since January. I believe you stated a while back that when I get my heads cnc'd...my cam was really going to be HAPPY..and come alive!...we shall soon see! Should be ready for Norwalk,next month!
Re: 4.2 KICKDOWN LEVER...AS OPPOSED TO THE 5.0? [Re: FuryBoy] #1478927
08/04/13 06:30 PM
08/04/13 06:30 PM
Locomotion Offline
Locomotion  Offline
Is your trans in or out of the car?
The pin/shaft it rides on comes out from inside the bellhousing after unscrewing a plug. Even out of the car, I wish I had another hand to do it. Gotta manipulate things carefully to get it out & in.
Re: 4.2 KICKDOWN LEVER...AS OPPOSED TO THE 5.0? [Re: 82ramIndy493] #1478928
08/05/13 09:53 AM
08/05/13 09:53 AM
Forest Lake, Minnesota
superbeejim Offline
superbeejim  Offline
You can change the lever in the car. Use a 12' 1/4 inch drive extension and a 1/4" flex socket and unscrew the plug. Some of the plugs have like a locktight sealant on them and you have to heat it up with a torch to get it out, and that should be done with the trans out of the car. I have broken the flex socket when the plug was tight and wasn't heated.
Re: 4.2 KICKDOWN LEVER...AS OPPOSED TO THE 5.0? [Re: Labratt] #1478929
08/05/13 10:41 AM
08/05/13 10:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Randy.. put the 4.2 arm in... it gives you a better
shift
EDIT
and all the things he suggested
Re: 4.2 KICKDOWN LEVER...AS OPPOSED TO THE 5.0? [Re: MR_P_BODY] #1478930
08/05/13 12:15 PM
08/05/13 12:15 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Hi,Mike! Yes..picking up a 4.2 lever..HD strut..and billet aluminum spring retainer from Mancini's today. Also,the MRE Race rebuild kit..as suggested by Gerry Tomala. I just have to decide what rear band to purchase. What do you suggest? Thanks! Randy
Re: 4.2 KICKDOWN LEVER...AS OPPOSED TO THE 5.0? [Re: Labratt] #1478931
08/05/13 02:58 PM
08/05/13 02:58 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
i have changed many levers in car with 1/4 ext and flex socket
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
