Page 2 of 5 1 2 3 4 5
Re: 383 starter size problem [Re: MOPARMIKE69] #1476902
08/02/13 05:12 PM
08/02/13 05:12 PM
Nashville, TN
MOPARMIKE69 Offline OP
Nashville, TN
Ok so I have counted the teeth... 130, I have measured the bellhousing...13 3/4 so it is an 11 inch. Therefore it must be the starter. I will be pulling it. Thanks to those who were helpful.
SORRY TYPO.... it is 15 3/4. Alum original bell housing. 130 teeth flywheel. The starter still hits the flywheel. I am out of town on business and plan to pull the starter Saturday. Makes no sense to me that it isn't lined up and engageing.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: 383 starter size problem [Re: RJS] #1476903
08/02/13 08:35 PM
08/02/13 08:35 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Back in my auto parts days a p/n2250 starter fit all bigblocks except HEMI.
Do you have the cast iron bell or the aluminum bell?
The cast iron needs the 143 tooth flywheel and the aluminum needs a 130 tooth
Guarantee that part number would not have fit my 64 300, 413, A745 manual trans. It required a direct drive starter.
Don't be the exception.
Re: 383 starter size problem [Re: Supercuda] #1476904
08/02/13 10:23 PM
08/02/13 10:23 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I guess I have to be more exact in my replies.
Never in a million years would a 64 anything be on my mind.
I only think in Muscle Car...
Re: 383 starter size problem [Re: RJS] #1476905
08/03/13 12:25 AM
08/03/13 12:25 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Guess a 64 Max Wedge B body is not a muscle car?
take the blinders off.
Re: 383 starter size problem [Re: MOPARMIKE69] #1476906
08/05/13 06:23 PM
08/05/13 06:23 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Wondering if you found the problem.
Re: 383 starter size problem [Re: pushbutton] #1476907
08/05/13 10:49 PM
08/05/13 10:49 PM
Nashville, TN
Nashville, TN
Ok ..I have been working on these cars for 40 + years and never ran into this. I finally got the starter out after removing just about everything to get the hooker headers out of the way so I could pull the starter. Starter is correct big block starter. Bell housing is alum original style. 15 3/4 from bolt to bolt. Flywheel is 130 teeth ..BUT! The flywheel hits the housing of the starter and the gear from the starter hit the side of the flywheel and cannot in gage!
AAAHHHGGGHHHHH!!!!!!!
No part number on bell housing, no way to measure the flywheel. Going to the Mopar Nats with measurements to see what I can find out. God I am pissed!
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: 383 starter size problem [Re: MOPARMIKE69] #1476908
08/05/13 11:04 PM
08/05/13 11:04 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Might check with Wayne Brewer at the Nats and see what he thinks. Sounds like you have a 10-1/2" flywheel. I can't understand why it would hit in a 11" bell. Thought maybe he would have responded to this thread by now,maybe too busy getting ready for the Nats. Thanks for the update. Have a safe trip i'm leaving thur morning myself.
Re: 383 starter size problem [Re: pushbutton] #1476909
08/05/13 11:11 PM
08/05/13 11:11 PM
Cincinnati, Ohio
superbeedave Offline
Cincinnati, Ohio
Gotta agree!
Re: 383 starter size problem [Re: MOPARMIKE69] #1476910
08/06/13 02:30 AM
08/06/13 02:30 AM
Cab_Burge Online work
Cab_Burge  Online Work
The casting number is on the bellhousing in one of the recessed holes on the aluminum bellhousings , it will read like 2974345 or someything similar. It will also have a code for the date and time it was cast on Write the casting number down and I will tell you which year and application that bellhousing is for
Re: 383 starter size problem [Re: Cab_Burge] #1476911
08/06/13 09:06 AM
08/06/13 09:06 AM
Nashville, TN
Nashville, TN
I will check for part number again. Here is a pic I took last night. It shows the flywheel position in relation to the hole for the snout of the starter. You can see it over laps.
Also can anyone measure from the bottom of the block to the edge of your flywheel. That seems to be a measurement that can be accurate enough to tell if the flywheel is too big. PLEASE????
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: 383 starter size problem [Re: MOPARMIKE69] #1476912
08/06/13 07:42 PM
08/06/13 07:42 PM
ill
dennismopar73 Offline
ill
as I posted before wrong fly wheel
Re: 383 starter size problem [Re: MOPARMIKE69] #1476913
08/06/13 09:49 PM
08/06/13 09:49 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Sorry but even Helen Keller knows that flywheel has to come out, is it just me?, or is that flywheel mounted "backwards"?
Re: 383 starter size problem [Re: DAYCLONA] #1476914
08/06/13 10:28 PM
08/06/13 10:28 PM
ill
ill
Re: 383 starter size problem [Re: DAYCLONA] #1476915
08/06/13 10:59 PM
08/06/13 10:59 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Does look like it is in backwards ...
Re: 383 starter size problem [Re: JohnRR] #1476916
08/07/13 01:04 AM
08/07/13 01:04 AM
Cincinnati, Ohio
Cincinnati, Ohio
To tell you the truth I thought from earlier when he poster that picture it looked kind of weird. I too thought it was backwards.
Re: 383 starter size problem [Re: superbeedave] #1476917
08/07/13 01:17 AM
08/07/13 01:17 AM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
That makes several of us. I was looking at the picture and it just didn't look right. If the flywheel is on backwards, how the heck could he bolt on the clutch and pressure plate?
Re: 383 starter size problem [Re: elmor353] #1476918
08/07/13 02:48 AM
08/07/13 02:48 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The pressure plate holes on flywheels are generally drilled thru and tapped, not blind holes, so in reality you could bolt the pressure plate on the "reverse" side,... here's the McLeod steel Bblk Mopar flywheel, looks to me the ring gear should be towards the engine side....
Re: 383 starter size problem [Re: MOPARMIKE69] #1476919
08/07/13 03:45 AM
08/07/13 03:45 AM
IL,USA
bdusted440 Offline
bdusted440  Offline
IL,USA
Your fly wheel is on backwards. Ring gear goes toward the engine . Or at least it does on mine. Was curious had to look at mine.LOL
Re: 383 starter size problem [Re: bdusted440] #1476920
08/07/13 08:54 AM
08/07/13 08:54 AM
Nashville, TN
Nashville, TN
OMG!!!!!! What an idiot! Well that settles that. Thanks for your help guys. Even with it in backwards it still has to be the wrong size. I know what I will be buying at the Nats!
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: 383 starter size problem [Re: MOPARMIKE69] #1476921
08/07/13 12:14 PM
08/07/13 12:14 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Can't tell from the pic but would it hit the starter housing if the flywheel was turned around?
If I had time I think I would pull the trans and check. If you have a 130 tooth F wheel and a 11" bell I don't see how it would. If this was the case you'd need a 11" flywheel anyway. Just make SURE what you have before you buy another flywheel.
