Page 1 of 5 1 2 3 4 5
383 starter size problem *Updated* +update+ #1476882
07/31/13 10:17 AM
07/31/13 10:17 AM
Nashville, TN
MOPARMIKE69 Offline OP
Nashville, TN
I bought a 70 runner with an original 383, 4sp set up. Engine already rebuilt and dynoed (I have the paper work) Anyway I get all the wiring etc ready for a start up and the starter hits the flywheel rather than engaging. I take off the inspection cover and sure enough the flywheel is almost rubbing the case of teh starter.
So are there different starters for 4 speeds? Tried to measure the flywheel in the car and it looks like 13inch. Maybe 12.5.
It has headers and before I remove the starter I need to know. It has to be either wrong starter or maybe even too big of a flywheel (God Forbid!)
Thanks for any insight.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: 383 starter size problem [Re: MOPARMIKE69] #1476883
07/31/13 10:29 AM
07/31/13 10:29 AM
ill
dennismopar73 Offline
ill
Wrong flywheel
Re: 383 starter size problem [Re: dennismopar73] #1476884
07/31/13 11:35 AM
07/31/13 11:35 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Pull the bell and count the teeth.there are only 2 wheels for a BB except hemi in cars.Either 130 or 143.I doubt a 143 will fit a 130 bell.If reversed the starter wont be near the teeth.Maybe someone used a truck setup.Rocky
Chrysler Firepower
Re: 383 starter size problem [Re: therocks] #1476885
07/31/13 11:38 AM
07/31/13 11:38 AM
Nashville, TN
Nashville, TN
So I possibly could replace the bell and fix the problem without pulling the clutch and flywheel?
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: 383 starter size problem [Re: MOPARMIKE69] #1476886
07/31/13 11:59 AM
07/31/13 11:59 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Its possible.Pull the bell and count the teeth.If you can turn the engine you can mark the teeth and turn the wheel and count them thru the inspection cover.I doubt a truck flywheel would fit in a car bell.Rocky
Chrysler Firepower
Re: 383 starter size problem [Re: MOPARMIKE69] #1476887
07/31/13 12:36 PM
07/31/13 12:36 PM
Do dyno operators use an elec motor attachment to start engines??? If not they would have used a regular starter in the bell. I would pull the starter & see what you see
Re: 383 starter size problem [Re: RapidRobert] #1476888
07/31/13 12:50 PM
07/31/13 12:50 PM
Nashville, TN
Nashville, TN
Those were my thoughts exactly, that's why my surprise when the starter did not fit.
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: 383 starter size problem [Re: MOPARMIKE69] #1476889
07/31/13 02:22 PM
07/31/13 02:22 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I have a big block blow proof bell housing that has the positioning holes for both a 130 tooth and a 143 tooth flywheel. Could the starter be bolted in the wrong holes for the size of flywheel? That would be an easy fix if that's the case.
...FAFO...
Re: 383 starter size problem [Re: skicker] #1476890
07/31/13 02:49 PM
07/31/13 02:49 PM
Nashville, TN
Nashville, TN
I will for sure be checking that out! If I could be so lucky? thanks
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: 383 starter size problem [Re: MOPARMIKE69] #1476891
07/31/13 03:05 PM
07/31/13 03:05 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
On a 11" bell the two widest two holes for the insp cover are 15 3/4" center to center.
Re: 383 starter size problem [Re: MOPARMIKE69] #1476892
07/31/13 04:32 PM
07/31/13 04:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What is making either of you think that the dyno used that bellhousing and starter to fire the engine? The last 2 dynos I was on , a Superflow and a Stuska , both had their own starter motor, even iff this bell was used as an adapter on the dyno the engine still would have ran.
The only Mopar engine that I know of with it's own 4 speed starter motor is the 66-69 Hemi. And I don't see why a 143 tooth wheel would not fit in a 130 tooth bellhousing , the bellhousing flange size is the same for all the bellhousings.
Re: 383 starter size problem [Re: MOPARMIKE69] #1476893
07/31/13 04:34 PM
07/31/13 04:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Does the car have a blowproof bell or a stock bell ? and not all bells are made to work with both size flywheels , especially not stock bells.
Re: 383 starter size problem [Re: JohnRR] #1476894
08/02/13 09:18 AM
08/02/13 09:18 AM
Nashville, TN
Nashville, TN
Ok so I have counted the teeth... 130, I have measured the bellhousing...13 3/4 so it is an 11 inch. Therefore it must be the starter. I will be pulling it. Thanks to those who were helpful.
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: 383 starter size problem [Re: MOPARMIKE69] #1476895
08/02/13 09:37 AM
08/02/13 09:37 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
10-1/2" flywheel with a 11" bell?
Re: 383 starter size problem [Re: pushbutton] #1476896
08/02/13 10:34 AM
08/02/13 10:34 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
11 inch bell and 130 tooth wheel wont work.The starter will be too far from the teeth.You need a 10 1/2 inch bell or 143 wheel.Only thing that fits both is a scattershield.Rocky
Chrysler Firepower
Re: 383 starter size problem [Re: therocks] #1476897
08/02/13 10:39 AM
08/02/13 10:39 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
This is very confusing , he says he has a 130 tooth wheel but the bell is only 13 3/4 , so it's not an 11" bell as that is 15 3/4 , and he says the starter gear is hitting the flywheel .
Mike what kind of starter is it, conventional or mini ? There is only so many starters that will physically bolt on there and the hemi direct drive is not one of them, so any one that should bolt on there should work , it's the same basic starter , you could take a starter from a /6 and bolt it on a 440-6pk and it will fit and turn the engine over.
Re: 383 starter size problem [Re: JohnRR] #1476898
08/02/13 11:24 AM
08/02/13 11:24 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Back in my auto parts days a p/n2250 starter fit all bigblocks except HEMI.
Do you have the cast iron bell or the aluminum bell?
The cast iron needs the 143 tooth flywheel and the aluminum needs a 130 tooth
Re: 383 starter size problem [Re: RJS] #1476899
08/02/13 11:55 AM
08/02/13 11:55 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Ron there are also cast iron 130 tooth bells prior to 1970, but a 70 should have the alum. one.
Re: 383 starter size problem [Re: JohnRR] #1476900
08/02/13 01:06 PM
08/02/13 01:06 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
John your right, I usually don't speak about those little engines (383)just 440's.
And I believe the mind is dusty on that part# I through out there, may have been 3250 starter.
Ron
Re: 383 starter size problem [Re: RJS] #1476901
08/02/13 02:47 PM
08/02/13 02:47 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Ron
The only difference between the starters is their torque rating, the nose of them that bolts to the bell or the auto trans is the same.
He still hasn't said what starter he is working with.? Even though one of the mounting holes is bigger than the diameter of the bolt going thru it the starter snout pilots into the bellhousing so there shouldn't be an alignment issue. If he is working with a starter without he pilot snout that could be causing the issue .
