73-4 B-Body Cruise Control Question #1476220
07/29/13 10:46 PM
07/29/13 10:46 PM
dart1962_440 Offline OP
It appears that the washer reservoir moves from the drivers side to the passenger side when cruise control was installed - can anyone confirm this?
I'm looking to install cruise on my 73 and the washer reservoir is in the way. Any pics I found on line have the reservoir moved to the other side when cruise is on the car.
Any help and pics of where everything mounts or moves to (like the washer lines and wiring) is appreciated.
Re: 73-4 B-Body Cruise Control Question [Re: dart1962_440] #1476221
07/30/13 07:52 AM
07/30/13 07:52 AM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
You are correct here. The cruise control cars have a different style bottle that is located away from the cruise control servo assembly. I think this bottle is more cube-ish than the normal bottle.
The standard bottle you have will not work unless you are going to to make it work. I don't know if it is repro'd (doubtful) so you may wish to post an ad looking for one here.
Good luck!
Re: 73-4 B-Body Cruise Control Question [Re: cjskotni] #1476222
07/30/13 09:11 PM
07/30/13 09:11 PM
Do you have any pictures of the cube-ish reservoir? My parts book only lists one part number and doesn't mention differences with cruise.
Re: 73-4 B-Body Cruise Control Question [Re: dart1962_440] #1476223
07/31/13 01:54 PM
07/31/13 01:54 PM
Georgia
skh Offline
skh  Offline
Georgia
Here you go!
Re: 73-4 B-Body Cruise Control Question [Re: skh] #1476224
07/31/13 01:57 PM
07/31/13 01:57 PM
Georgia
skh Offline
skh  Offline
Georgia
And here's what it looks like NOS.
7796773-Fullpagephoto.pdf (127 downloads)
Re: 73-4 B-Body Cruise Control Question [Re: skh] #1476225
07/31/13 07:08 PM
07/31/13 07:08 PM
Thank You!
Wonder why my parts book doesn't list it.
