Fuel system return line question #1475135
07/27/13 11:03 PM
07/27/13 11:03 PM
Medina, OH
dart440_72 Offline OP
Medina, OH
Hello all,
I am gathering the supplies to change out my BG280 to a Holly Dominator fuel pump. I have never run a return style system. I will be using -10 for the feed, is it ok to run -8 for return?
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: Fuel system return line question [Re: dart440_72] #1475136
07/27/13 11:07 PM
07/27/13 11:07 PM
Hamiltucky
RBDuster Offline
RBDuster  Offline
Hamiltucky
That is is what I used.
Re: Fuel system return line question [Re: RBDuster] #1475137
07/28/13 02:22 AM
07/28/13 02:22 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
With my BG 240 , they recommend a -8 feed and -10 return.
Who am I to question why ? That's what I did.
It sort of makes sense , as the -8 should be able to supply plenty of volume for a small block single carb deal like mine and the return will not provide any restriction.....so I guess on paper , it's all good.
The manufacturer should be able to provide requirements for their stuff I bet.
Re: Fuel system return line question [Re: tubtar] #1475138
07/28/13 03:04 AM
07/28/13 03:04 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I run the same feed as return,less extra fittings and hose to stock. Makes since to me.
Re: Fuel system return line question [Re: dart440_72] #1475139
07/30/13 10:20 AM
07/30/13 10:20 AM
an8sec70cuda Offline
Aeromotive A1000 pump on my cuda w/ a -10 feed and -8 return. Heard the same things you have and was concerned my -8 wouldn't work...called Aeromotive and the tech guy said it'd work no problem. That was almost 4 years ago.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Fuel system return line question [Re: tubtar] #1475140
07/30/13 12:04 PM
07/30/13 12:04 PM
Az
Crizila Offline
Crizila  Offline
Az
You always want the return line to be bigger than the feed line. You want zero back pressure on the return line. -8 feed and -10 return would be good. Keep the 90 degree bends to a minimum on all lines.
Fastest 300
Re: Fuel system return line question [Re: Crizila] #1475141
07/30/13 05:03 PM
07/30/13 05:03 PM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
Does the return at the tank need to be above fuel level? I've noticed that low pressure race setups are above and factory high pressure setups are below. Will a low pressure high flow race pump for non fuel injection work with a return in the middle of the tank?
NMCA NSS 67 Coronet
Re: Fuel system return line question [Re: Barry70GTX] #1475142
07/30/13 05:54 PM
07/30/13 05:54 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
With no scientific evidence , I am going to say yes.
Plumb it into the filler neck or top of the tank for the same reason as using a larger line. You don't want the back pressure that forcing returned fuel to the tank through 1/2 a tank of fuel would provide.
If you're using a cell , there will be a fitting located where ? Yes....on the top.
I put mine on the top front on the pass side because that is the side the return runs down. An oval track deal would want a little more thought than that.
Re: Fuel system return line question [Re: an8sec70cuda] #1475143
07/30/13 06:00 PM
07/30/13 06:00 PM
Renton Washington
Triple Threat Offline
Renton Washington
Same way my car is, no problem on pump gas, race gas or E85.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Fuel system return line question [Re: Barry70GTX] #1475144
07/30/13 06:07 PM
07/30/13 06:07 PM
Mine returns through the factory pickup tube...below fuel level.
CHIP
Re: Fuel system return line question [Re: an8sec70cuda] #1475145
07/30/13 07:26 PM
07/30/13 07:26 PM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
I had a -8 feed and -6 return (which worked fine for an EFI application) and could not get the fuel pressure below 12 psi. Ended up putting a dead head reg between the return reg and the carb to knock it to 6psi. Fuel still circulates and keeps the pump happy.
It's a bandaid, but it works fine and was cheaper than buying all new line and fittings for the return line.
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: Fuel system return line question [Re: Barry70GTX] #1475146
07/30/13 07:57 PM
07/30/13 07:57 PM
Az
Crizila Offline
Crizila  Offline
Az
Yes.
Fastest 300
Re: Fuel system return line question [Re: tubtar] #1475147
07/31/13 11:02 AM
07/31/13 11:02 AM
Barry70GTX Offline
Barry70GTX  Offline
I had searched for an answer to that and found nothing on it.
I have a car with a stock tank and plumbed the return at the sending unit. 3/8 fuel line with 1/2 return. It was working fine until I filled the tank up. The pump started surging after the fill up.
It's a Mallory 140 pump. Looks like I'll be moving the return.
NMCA NSS 67 Coronet
Re: Fuel system return line question [Re: Barry70GTX] #1475148
08/13/13 01:37 PM
08/13/13 01:37 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I meant to reply to this a few weeks ago. I just sumped my tank, didn't want my return to be below fuel level for obvious reasons.
Welded a tube into the filler neck. Hogged out the pressure relief of the cap to make it "vented". works great so far with a BG220 pump. 1/2 SS hardline front to rear.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
