Re: Burning Sparkplug Wire Boots
[Re: elmor353]
#1474467
07/26/13 08:48 PM
07/26/13 08:48 PM
Posts: 21,091 Niles , Ohio
therocks
Niles , Ohio
We have Hookers on the 360.My 65 440 has 2 inch TTIs and the 62 413 has 2 1/8 tubes.All have Taylor Spiro Pros.Mine are at least 12 years old and the others are at least 5 years.None melted.The 62 does have an insulated cover on 7 as its real close.My TTIs are real close and they dont melt or miss.Rocky
Chrysler Firepower
[Re: elmor353]
#1474468
07/26/13 09:51 PM
07/26/13 09:51 PM
RapidRobert
I'm just strickly brainstorming on a Fri night, could a person wrap a thin piece of asbestos or similar insulation around the boot & maybe paint it to make it presentable. Someone way back in Chrysler Power magazine iirc adapted a set of metal ends of some sort that came on a set of factory plug wires & it was a 4 or 6 cyl as they needed more than 1 set & it was the only thing they ever found that worked (2.2?). Unless there's a plug with a shorter insulator to gain some air space again just thinking out loud
[Re: ahy]
#1474470
07/26/13 11:28 PM
07/26/13 11:28 PM
Posts: 1,083 SE PA
Yellow Fever
SE PA
[Re: Yellow Fever]
#1474472
07/26/13 11:44 PM
07/26/13 11:44 PM
Posts: 4,968 WI
Dcuda69
WI
[Re: elmor353]
#1474473
07/26/13 11:52 PM
07/26/13 11:52 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Please post pictures. We'd love to see pictures of the problem areas. Closer to the spark plug/primary the better. Thanks .. We've made a bunch of sets for Hookers. Sometimes I swear they jig the same parts numbers differently. . Thanks much.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: Colin Frolick]
#1474477
07/27/13 12:32 AM
07/27/13 12:32 AM
Posts: 36,840 South San Francisco, Californi...
MidPenMopar
Looking for fun? Keep looking
i have these little fireproof socks on my plug wires next to headers. they work well.
I got those too along with the Accel high heat wires. So far with both of that protection things a re doing ok.
Still may get some Firecore 50's back on though. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: NITROUSN]
#1474484
07/28/13 04:30 PM
07/28/13 04:30 PM
sunroofgtx
Cleveland
Just an FYI.. Natural-color Heat Resistant Boots have a heat rating of 1500 degrees. When they add a color, it divides that number in half. The boot then takes on the heat rating of the die in the fabric. That's why the dye is gone in the hotter areas of your boots. If the correct type boots are used at each cylinder plug, everything should work ok.
