Burning Sparkplug Wire Boots #1474466
07/26/13 06:08 PM
07/26/13 06:08 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline OP
elmor353  Offline OP
E
I've got Hooker headers on my 440 in my pickup. It keeps burning the sparkplug wire boots. I want to prevent arcing and misfire. Any suggestions on how to correct this? Does anyone make boots that will withstand the high heat?
Re: Burning Sparkplug Wire Boots [Re: elmor353] #1474467
07/26/13 08:48 PM
07/26/13 08:48 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We have Hookers on the 360.My 65 440 has 2 inch TTIs and the 62 413 has 2 1/8 tubes.All have Taylor Spiro Pros.Mine are at least 12 years old and the others are at least 5 years.None melted.The 62 does have an insulated cover on 7 as its real close.My TTIs are real close and they dont melt or miss.Rocky
Chrysler Firepower
Re: Burning Sparkplug Wire Boots [Re: elmor353] #1474468
07/26/13 09:51 PM
07/26/13 09:51 PM
I'm just strickly brainstorming on a Fri night, could a person wrap a thin piece of asbestos or similar insulation around the boot & maybe paint it to make it presentable. Someone way back in Chrysler Power magazine iirc adapted a set of metal ends of some sort that came on a set of factory plug wires & it was a 4 or 6 cyl as they needed more than 1 set & it was the only thing they ever found that worked (2.2?). Unless there's a plug with a shorter insulator to gain some air space again just thinking out loud
Re: Burning Sparkplug Wire Boots [Re: RapidRobert] #1474469
07/26/13 11:15 PM
07/26/13 11:15 PM
IN
ahy Offline
ahy  Offline
IN
On my setup (BB low deck, Ed heads, TTI's) standard wire sets didn't work out very well. Boot angles weren't right and I burned one or two. I switched to MSD adjustable boot wires and problem solved. Adjusting the boots to get best clearance worked. Worth a look in your situation.
Re: Burning Sparkplug Wire Boots [Re: ahy] #1474470
07/26/13 11:28 PM
07/26/13 11:28 PM
SE PA
Yellow Fever Offline
SE PA
I bought several sets of these, Accel Extreme 9000 wires and they've worked out well.
http://www.jegs.com/p/Accel/Accel-Extreme-9000-Heat-Reflective-Ignition-Wire/745355/10002/-1
Re: Burning Sparkplug Wire Boots [Re: Yellow Fever] #1474471
07/26/13 11:33 PM
07/26/13 11:33 PM
SE PA
SE PA
The 9003's are universal and you can bend the boot for header clearance.
This guy has em cheap and you can get different boots for the dist. end.
http://www.ebay.com/itm/Accel-9003-Unive...e95&vxp=mtr
Re: Burning Sparkplug Wire Boots [Re: Yellow Fever] #1474472
07/26/13 11:44 PM
07/26/13 11:44 PM
WI
Dcuda69 Online content
Dcuda69  Online Content
WI
I have Taylors on mine...though I custom made them w/Taylor wire and ends/boots to fit my setup(BB w/CPPA headers in an A-body) This guy will make you what you need...will be my next set
https://www.customwiresets.com/home.php
Re: Burning Sparkplug Wire Boots [Re: elmor353] #1474473
07/26/13 11:52 PM
07/26/13 11:52 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Please post pictures. We'd love to see pictures of the problem areas. Closer to the spark plug/primary the better. Thanks .. We've made a bunch of sets for Hookers. Sometimes I swear they jig the same parts numbers differently. . Thanks much.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Burning Sparkplug Wire Boots [Re: Yellow Fever] #1474474
07/27/13 12:05 AM
07/27/13 12:05 AM
South San Francisco, Californi...
MidPenMopar Offline
Looking for fun? Keep looking
MidPenMopar  Offline
I got those too and they work well, BUT they are brittle and break easily!! Just putting them on I broke two of the porcelain ends!!
My Firecore 50's are the best wires ever, but they burnt up next to my headers.
Re: Burning Sparkplug Wire Boots [Re: MidPenMopar] #1474475
07/27/13 12:29 AM
07/27/13 12:29 AM
Southern CA
Colin Frolick Offline
Southern CA
i have these little fireproof socks on my plug wires next to headers. they work well.
Re: Burning Sparkplug Wire Boots [Re: Colin Frolick] #1474476
07/27/13 12:32 AM
07/27/13 12:32 AM
Southern CA
Southern CA
they also come in colors
Re: Burning Sparkplug Wire Boots [Re: Colin Frolick] #1474477
07/27/13 12:32 AM
07/27/13 12:32 AM
MidPenMopar Offline
MidPenMopar  Offline
I got those too along with the Accel high heat wires. So far with both of that protection things a re doing ok.
Still may get some Firecore 50's back on though.
Re: Burning Sparkplug Wire Boots [Re: elmor353] #1474478
07/27/13 10:59 AM
07/27/13 10:59 AM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Ceramic boots are what you need. I put these Accel wires with ceramic boots on my Power Wagon's 383 & never had a burn problem since.
$129 from Summit. Here's the link http://www.summitracing.com/parts/acc-9001c
Also a pic on my 383 & you can see the slip on "burn proof" covers
have taken some heat, but the wires are like new.
Re: Burning Sparkplug Wire Boots [Re: Triggerfish] #1474479
07/27/13 11:04 AM
07/27/13 11:04 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
My headers turned a couple MSD wire boots into marshmallow material. I replaced them with Taylor spiro pro wires with these types of boots, they work great.
Re: Burning Sparkplug Wire Boots [Re: sunroofgtx] #1474480
07/28/13 12:29 PM
07/28/13 12:29 PM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
Mine are fine with the 440 and hookers. Just need the angles in the right areas.
Re: Burning Sparkplug Wire Boots [Re: 1fastrunner] #1474481
07/28/13 04:03 PM
07/28/13 04:03 PM
E
elmor353 Offline OP
elmor353  Offline OP
E
I'm running straight boots on the current wires. I can't see where changing the angles is going to solve this problem. It is only the the last 3/4 of an inch of the boots that burn. They are just too close on numbers 4,6,3 and 5. The front and rear cylinders on each side are fine. I tried dimpling the pipes a bit, but doesn't help the situation, as I can't get much more clearance. Maybe ceramics are the way to go, but if the diameter of the boot is any larger than the ones I have, they may not clear the headers.
Re: Burning Sparkplug Wire Boots [Re: elmor353] #1474482
07/28/13 04:11 PM
07/28/13 04:11 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Some boots are just plain junk. I think the higher the silicone content the more heat resistant they are.
Re: Burning Sparkplug Wire Boots [Re: elmor353] #1474483
07/28/13 04:14 PM
07/28/13 04:14 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Also an incorrectly tuned motor can have excessive exhaust heat and be hard on boots.
Re: Burning Sparkplug Wire Boots [Re: NITROUSN] #1474484
07/28/13 04:30 PM
07/28/13 04:30 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Just an FYI.. Natural-color Heat Resistant Boots have a heat rating of 1500 degrees. When they add a color, it divides that number in half. The boot then takes on the heat rating of the die in the fabric. That's why the dye is gone in the hotter areas of your boots. If the correct type boots are used at each cylinder plug, everything should work ok.
Re: Burning Sparkplug Wire Boots [Re: elmor353] #1474485
07/29/13 11:56 PM
07/29/13 11:56 PM
East Coast
MoparRoger Offline
MoparRoger  Offline
East Coast
Did you try using the "shorty" spark plugs ? I do on 4 of the cyls & never burn my Accel 8mm boots with Hooker Comp headers
