512 STROKER START UP QUESTION #1473368
07/24/13 02:03 PM
07/24/13 02:03 PM
Uranus
strokerchall Offline OP
Uranus
A 512 stroker I recently purchsed has been sitting for over a year,it has a 1000 miles on it.Can i getr away with just spinning
it over with the
coil wire off to lube the top end or do I need to prime it?
Re: 512 STROKER START UP QUESTION [Re: strokerchall] #1473369
07/24/13 02:09 PM
07/24/13 02:09 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
If it was me I would prime it. It's not that big a deal.
Re: 512 STROKER START UP QUESTION [Re: 5spdcuda] #1473370
07/24/13 03:46 PM
07/24/13 03:46 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
Its not that big a deal, prime it. Cheap Insurance
Re: 512 STROKER START UP QUESTION [Re: strokerchall] #1473371
07/24/13 03:55 PM
07/24/13 03:55 PM
One head oils when #8 is firing (DR side iirc) & one head oils when #6 is firing. going by the rotor position with a 1&1/4" socket/breaker bar turn to whichever of the two is closest & preoil then hand turn to the other position & preoil. I like to do 8 first then go 3/4 turn clockwise to #6 (timing slit will be on zero on the timing tab) & when done preoiling that side then back up the crank CCW slightly to 10 BTDC mild cam/15 wild cam) & clock the intergear so the rotor is under #6 & the magnet is dead even with the tooth
Re: 512 STROKER START UP QUESTION [Re: RapidRobert] #1473372
07/25/13 01:07 AM
07/25/13 01:07 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
The problem with priming with the starter. Is it takes a long time to reach full pressure. You crank for an eternity with no pressure. Lobes, dry, bearings dry, piston walls dry. When you finally do have pressure, the damage is done.
I also am pretty confindent some things like rings and piston skirts will never get oil from cranking. That's why prelubing and an INSTANT FIRE UP is important.
