Re: 4 Speed Breakage
[Re: TJP]
#1473200
07/25/13 07:59 AM
07/25/13 07:59 AM
Posts: 6,445 Missouri
68KillerBee
Missouri
From one of your posts in the old thread Quote:
with the clutch, pressure plate, d-shaft and trans out there was no vibration at any rpm. put in new clutch, pressure plate, flywheel (refurbished from brewers), rebuilt transmission, new throw out bearing, and the vibration is still there
Re read that several times and think it through, the answer appears to be somewhere in the second sentence of the above quote
Refurbished flywheel from a well known, all Mopar transmission guy?
The camera angle was weird on that pic as the flywheel looks even all the way around once fully under the car. It won't budge anywhere with a pry bar. I'll be able to talk with my dad tomorrow to see what the plan of attack is.
edit: also, the vibration is not as bad as it used to be before all of these new parts were put on it. It wasn't jarring or anything horrible, just enough to annoy you. But most of that subsided. Since we have been working on this problem, it has gone 2-300 miles at the most. That's including the old set up and when the problem appeared. So he hasn't driven it much at all because of it, just don't want you all to think that he's been driving it all around with this problem. I've driven my super bee 25,000 miles on a transmission and bell set up that we did years ago. Have had my transmission in and out 3 times since I've owned it. Not saying mistakes don't happen, but we've done this in the past and no problems.
Also to clarify exactly what the vibration was felt in all of these scenarios: -At a dead stop with clutch pushed in and revved up and with clutch released when revved up. -Driving, no particular speed was it felt at, only at the rpm level. (Just the same thing as if it was at a dead stop). So really that takes out the driveshaft, although I understand "good" pinion angle is not guaranteed. Would the possibility of poorly welded front floor pans cause a flex on the area where the transmission mount is....? Trying to think out of the box . I still will investigate all ideas you all have written. I really do appreciate it everyone
[Re: 68KillerBee]
#1473201
07/25/13 08:27 AM
07/25/13 08:27 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Even you have a free moment, see if you can turn the motor or rock it from the crank damper. If the flywheel moves then its all good for sure, I forgot to mention this the other day.
I hope the engine is ok, I'm just trying to analyze the damage and posit the initial failure point. Until you have it apart all we have is the pictures posted to go by and description of events and so this is all speculation of course.
[Re: gdonovan]
#1473202
07/25/13 09:08 AM
07/25/13 09:08 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
With the way the trans looks the motor might not turn.One I has would not turn till we pulled the trans and bell.Motor was good.Rocky
Chrysler Firepower
[Re: 68KillerBee]
#1473203
07/25/13 11:16 AM
07/25/13 11:16 AM
Posts: 75,089 A Banana Republic near you.
JohnRR
Have the floor pans been replaced ?
I'd be looking at an imbalance with the Flywheel and pressure plate .
Did you confirm the flywheel was neutral balance or did you just ASSuME it because you got the flywheel from "a well known, all Mopar transmission guy" ?
Not that I'm knocking Wayne, but I have bought high dollar parts from big name companies that were not as good as they should have been.
[Re: JohnRR]
#1473204
07/25/13 11:33 AM
07/25/13 11:33 AM
68KillerBee
Missouri
Ahh, my favorite word you use ha. You told me about that in the original thread, so we found a place to do it. I'd have to find the receipt to verify what they did. And yes, the floor pans had been replaced.
[Re: JohnRR]
#1473205
07/25/13 11:45 AM
07/25/13 11:45 AM
Posts: 15,489 Omaha Ne
TJP
Omaha Ne
I would not even be thinking about the floor pans etc. An old engineering manager of mine would call that "chasing ghosts". The answer is somewhere in your previous post. The vibration appears after installing the clutch assembly and transmission, OK that would indicate to me the vibration was due to 1. something in the clutch assembly. 2. A problem with the bell housing itself 3. The transmission. Another thing to keep in mind is, we don't know that the vibration caused the failure only that it was there before. the 40 year old bell housing may have been fractured due to being dropped and it was not apparent. I have seen 2 very similar failures (almost identical) both were caused by an incorrect bearing retainer OD to Bell housing ID.
[Re: TJP]
#1473206
07/25/13 12:14 PM
07/25/13 12:14 PM
68KillerBee
Missouri
I see what you're saying, but this has been happening after two different clutches, pressure plates, bellhousings, flywheels, bearings in the crank and after a complete re-haul of the transmission, new fork etc. The car has never been wrecked either (i don't think I answered that earlier).So I can't dismiss something as dumb(trust me, I know it is dumb) as that. But it could have simply been the bellhousing, i believe that was the first thing I found in the road when I retrieved pieces. Once we take it out I will check the bearing sizes. I'll be back with more info/pictures on Wednesday at the earliest, or if dad pulls it out by himself before then. Isn't too hard since the only thing holding the transmission is the transmission mount . Thanks again fellas
[Re: TJP]
#1473207
07/25/13 12:23 PM
07/25/13 12:23 PM
Posts: 460 Oklahoma
VoodooCLD
Oklahoma
Not to highjack the post, but i bought one of those converter rings to put on my bearing retatiner from brewers. Has there ever been any instances of them falling off and ending up in the clutch? It's got me kind of worried.
[Re: VoodooCLD]
#1473208
07/25/13 12:37 PM
07/25/13 12:37 PM
Posts: 95 NW INDIANA
ta3834bbl
NW INDIANA
In the second picture of this thread, it looks like there is discoloration next to the threads , is that rust from a previous fracture or is that oil hanging in the casting ?
67 Dart GT Convertible 273 68 Barracuda 383 68 Roadrunner 383 4spd 1 '01 Ram 2500 4x4 diesel 2 '02 Rams 1500 4x4's 4.7s 3 '03 Rams 2 1500's 4x4 and 1 2500 hemi 4x4 Oh, and a 03 Grand Cherokee and an '00 durango
[Re: 68KillerBee]
#1473209
07/25/13 01:48 PM
07/25/13 01:48 PM
JohnRR
Tell us about the engine rebuild , did it involve new parts other than rings and more importantly a balance job ?
I can't see the floor pans being the cause as something would have to vibrate to cause it to resonate thru the floors that would have had to have been very poorly attached to the car.
[Re: 68KillerBee]
#1473212
07/26/13 04:05 AM
07/26/13 04:05 AM
Posts: 6,301 colorado
a12superbee
colorado
Everything posted sure points to not being balanced as an assembly. Your dads sacrifice has led to one of the best threads in quite a while though. Buy him a root beer for us.
I can't afford this.
mark
[Re: 68KillerBee]
#1473213
07/26/13 10:08 AM
07/26/13 10:08 AM
JohnRR
The motor rebuild was a different block and all internal stuff was different. The old 440 is still sitting in the shed with just the heads off, intake and carb off, they're on the new block. The only reason flywheel and stuff was switched originally was bc we were looking for what the vibration was from. Different motor, flywheel, clutch, bellhousing, etc and it still the exact same symptoms (vibration when in higher rpm's). I may jump on taking parts out Saturday, just because I'm curious on the extent of damage and of course to get your all's help.
Then it's driveline related originally.
[Re: dogdays]
#1473216
07/26/13 02:35 PM
07/26/13 02:35 PM
JohnRR
JohnRR, you may be forgetting that he says it vibrated with the clutch pedal in, also vibrated with the clutch pedal out but the transmission in neutral.
I'm beginning to wonder if it is either a perception problem or something off the wall like a distributor with slightly misshaped toothed wheel or cam.
R.
Could be all of the above ???
Was the car in motion while the clutch pedal was pushed in or was it stationary ?
IF stationary that points to an engine imbalance , but with 2 different engines ?
[Re: JohnRR]
#1473218
07/29/13 08:11 AM
07/29/13 08:11 AM
68KillerBee
Missouri
R.
Hadn't thought of that. I had a problem that I coulda swore was my carburetor. But putting a different coil on it fixed the problem, even though I was just changing it just to change it. Who knows at this point what it is, I haven't messed with it and don't know if dad has either.
Clutch pushed in and out, moving or sitting still and it is felt.
More to come in a few days.
