Re: Cracking Rear Brake Shoes
[Re: CYACOP]
#147255
11/08/08 12:37 PM
11/08/08 12:37 PM
Posts: 3,958 SW Fla.
CYACOP
SW Fla.
[Re: CYACOP]
#147256
11/08/08 12:48 PM
11/08/08 12:48 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Cracks in shoes face are normal. Not uncommon to see when I check brakes. However I would look at the side of the shoe though for fresh metal.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: stumpy]
#147261
11/08/08 04:16 PM
11/08/08 04:16 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I have had very few shoes crack. I have replaced a large nimber of brake shoes on customers cars that weren't cracked. Cracked shoes usually come from cars with discolored drums which is another sign of hot brakes. It tells me your doing a bit of hard braking or your drums have been cut thin and can't disapate heat fast enough.
Not normal, overheating brakes....
[Re: ThermoQuad]
#147263
11/08/08 06:42 PM
11/08/08 06:42 PM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
Since they are on the rear, let's bring up the "burnout" or Brake Torquing as another reason there was a ton of heat. Also possible was the shoes were too tight against the drum and were dragging creating the heat. Another common problem with rear shoes is the parking brake being adjusted too tight or rusted and sticking holding pressure on the shoes all the time.. If it were my car I would immediate replace them, I have seen a few shoes like these fracture and chunks lock up the wheel.
[Re: kenny b]
#147265
11/08/08 09:56 PM
11/08/08 09:56 PM
Posts: 32,943 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
Simple answer. All bonded shoes crack over time and usage from heat. Quality riveted shoes equals problem solved"
That isn't true, I have done better than 1000 brake jobs over the years and bonded shoes don't all crack. Cracking is caused when the shoes become hard from being over heated. That isn't a normal situation. Normally shoe material stays flexable if not over heated and won't crack. Riveted shoes do the same when they get too hot. You're an auto shop teacher and should know that.
[Re: stumpy]
#147266
11/08/08 10:24 PM
11/08/08 10:24 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
There are those that do...& Those that teach...
[Re: 1_WILD_RT]
#147267
11/08/08 11:27 PM
11/08/08 11:27 PM
Posts: 7,541 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
I can report cracked linings due to overheating of rear brakes.
The evidence is pretty clear because I am struggling with uneven brake pressure on the rears and I can tell you this: The side with the brake that is doing all the work is cracking (and squeaking).
The other side with less pressure is just fine.
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
