dyed arm rests? #1471102
07/20/13 10:12 PM
07/20/13 10:12 PM
Forest Lake, Minnesota
superbeejim Offline OP
I have some black arm rests that were dyed white years ago and there is some areas that the black has shown thru. Is there a product that works on vinyl that you can put various shades of white on it to match the other stuff or do you have to do it all? I see that Rust-Olium has a spray can that is supposed to work on vinyl or is there a better spray dye out there I should get? Thanks, Jim
Re: dyed arm rests? [Re: superbeejim] #1471103
07/21/13 11:03 AM
07/21/13 11:03 AM
michigan
440whiteboy Offline
440whiteboy  Offline
michigan
Its been some time since I have done this.
I think Eastwood has paint cans to use.
They only see Stars...
when hit by a Mopar!
Re: dyed arm rests? [Re: superbeejim] #1471104
07/21/13 12:19 PM
07/21/13 12:19 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
SEM spray dye works well... (I did the ones in my Torana years ago from a sort of chamois color to black and have held up great)
(I have used the ones from Classic Industries too since they are local to me and needed some quickly, and that worked fine, might be made by sem,eastwood, etc perhaps?)
Going from black to white will be harder than the other way around, might need a couple of coats of course.
Re: dyed arm rests? [Re: OzHemi] #1471105
07/21/13 07:56 PM
07/21/13 07:56 PM
South-east Mn
blaze Offline
blaze  Offline
South-east Mn
SEM? How or where do I find them?
Re: dyed arm rests? [Re: blaze] #1471106
07/22/13 04:58 PM
07/22/13 04:58 PM
Utah
E
Eagleone1983 Offline
E
Utah
I did mine in SEM. Went from brown to black. Looked good for a little bit but now they are starting to get scratched up. I prepped the crap out of it and it still scratched off. Same thing happened to my horn pad, however all the hard plastic parts like the kick panels and steering column cover are holding up nice.
Re: dyed arm rests? [Re: Eagleone1983] #1471107
07/22/13 07:05 PM
07/22/13 07:05 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Try PPG elastromeric lacquer.I have sprayed many colors and had very good results.It is only available at a PPG automotive retailer.They can also put it in a spray can.Not cheap but has excellent adhesion.
Re: dyed arm rests? [Re: 5carguy] #1471108
07/22/13 07:30 PM
07/22/13 07:30 PM
pa
clonewars Offline
clonewars  Offline
pa
May sound weird give plasti dip a try you can buy it Lowe's or walmart or go online and you can get a kit and create your own shade I used plasti dip on many things wheels,,rubber,outside trim I even painted a car with it best thing about it is its a rubber compound and if you don't like Result just peel it off like a piece of vinyl it's simple and easy and last forever
