Page 3 of 14 1 2 3 4 5 13 14
Re: replacement cab. [Re: scratchnfotraction] #1470440
08/04/13 09:46 AM
08/04/13 09:46 AM
scratchnfotraction Offline OP
slowly comeing together.
Re: replacement cab. [Re: scratchnfotraction] #1470441
08/04/13 09:48 AM
08/04/13 09:48 AM
Re: replacement cab. [Re: scratchnfotraction] #1470442
08/04/13 09:53 AM
08/04/13 09:53 AM
a little paint to keep the flash rust down, go back and grind the welds down flat. and its patched.
do a little sand blasting on the surface rust on the rest of driver floor, then a coat of bed liner sprayed inside.
then it is ready to flip on its back so I can weld the back side of patch, then coat the firewall/cab bottom with the bed spay on bed liner.
ACE did a 59 chebby and I do like the finished look of the spray on bed liner inside and out of the cab. easy clean up with a hose and not soggy carpet.
Re: replacement cab. [Re: scratchnfotraction] #1470443
08/04/13 12:46 PM
08/04/13 12:46 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
1981 Dodge D150 360 auto
Re: replacement cab. [Re: scratchnfotraction] #1470444
08/05/13 08:29 PM
08/05/13 08:29 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Copycat!! What are you going to use?
Re: replacement cab. [Re: redraptor] #1470445
08/06/13 03:01 PM
08/06/13 03:01 PM
last 3 trucks Ace has sprayed,he used the rustoleum rubberized spray bed liner.
same finish look you have there in the raptor.
the 64 chebby got it in the lower cab with a gloss white dash and upper 1/2 of cab.
the 59 chebby got same inside with a full undercoating and all of the underhood/engine bay.
what was a fast patch up to swap in the 5 speed is turning into a little more body work than i had thought about doing.
but I am really enjoying the project again for a change.
I am ready to flip the cab and weld up the bottom next,then on to sparying the bedliner.
Re: replacement cab. [Re: scratchnfotraction] #1470446
08/06/13 04:52 PM
08/06/13 04:52 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: replacement cab. [Re: 340SHORTY] #1470447
08/06/13 05:34 PM
08/06/13 05:34 PM
RI
MOPARS6768 Offline
MOPARS6768  Offline
RI
Looks like you are moving right along I will be following this closely I just started my first cab swap, I havnt gotten nearly as far as you yet my cab is still hanging from the beam in my garage here are a few pics of my project.
Re: replacement cab. [Re: MOPARS6768] #1470448
08/06/13 05:45 PM
08/06/13 05:45 PM
RI
MOPARS6768 Offline
MOPARS6768  Offline
RI
Here are my trucks befor I pulled the donor cab
Re: replacement cab. [Re: MOPARS6768] #1470449
08/06/13 06:07 PM
08/06/13 06:07 PM
RI
MOPARS6768 Offline
MOPARS6768  Offline
RI
another
Re: replacement cab. [Re: scratchnfotraction] #1470450
08/08/13 05:27 PM
08/08/13 05:27 PM
eastern, pa.
cudabitten Offline
cudabitten  Offline
eastern, pa.
You gonna bring donuts over to the neighbor?
Re: replacement cab. [Re: cudabitten] #1470451
08/10/13 09:41 PM
08/10/13 09:41 PM
got some spray on bed liner done today, now to let it cure a couple days and it is flip over for bottom side.
Re: replacement cab. [Re: scratchnfotraction] #1470452
08/10/13 09:43 PM
08/10/13 09:43 PM
another one
Re: replacement cab. [Re: scratchnfotraction] #1470453
08/10/13 09:43 PM
08/10/13 09:43 PM
and another shot.
20$ for sheet metal,60$ for bedliner = 80$ for patch work so far. with cab/tax = 400$ to replace the 85 cab. well worth the effort and cash so far. hope to squeeze it all in under the 550$ cash mark.
going to need another roll of wire for welder, another gallon of bedliner to finish up the cab.
little progress at a time.
the 5 speed conversion is coming in under 900$ but still need to build a drive shaft yet.
the whiplash roller cam swap added another 550$ to the bill.
it will be like a new truck for less than 2000$ invested. which is better than a 350$/month 5 yr payment plan right now.
Re: replacement cab. [Re: scratchnfotraction] #1470454
08/10/13 11:38 PM
08/10/13 11:38 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Isnt the bedliner on the inside gonna get messed up when your weldung on the bottom ?
I am truckless..
Re: replacement cab. [Re: 340SHORTY] #1470455
08/11/13 12:29 AM
08/11/13 12:29 AM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
Mike, lookin D****** good my friend!!! I took my junkyard truck for a ride today; have to dial in my distributor as I switched from an MSD mechanical to a firecore vacuum advance. It runs a lot cooler with the vacuum but I think it suffers a bit on HP. It lights them up on demand and is a blast to drive. Bodywork and paint are next but it will be a while as I am enjoying it as a rat rod and the looks on peoples faces when I pop the hood or shut them down. LOL
Re: replacement cab. [Re: 340SHORTY] #1470456
08/11/13 08:56 AM
08/11/13 08:56 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
I think he's done with the cab floor.
Re: replacement cab. [Re: redraptor] #1470457
08/13/13 08:14 PM
08/13/13 08:14 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
I did a whole cab swap on my truck last year,its a lot more solid and quiet now Your donor cab didnt have the lower rear window trim did it? I would be interested if so.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: replacement cab. [Re: redraptor] #1470458
08/14/13 11:07 PM
08/14/13 11:07 PM
yes, i got it done, waiting to do the rocker next,i got to chop rust out first, then chop greenie up a little more to patch the rocker.
when its all done it will get another gallon bedliner on the bottom. if you look I did the a-pillers/jambs and plan to do the lower rockers along with the floot bottom.
once thats done its on to the front drip rail/roof repair. clean/cut/weld/allmetal should fix up the weak spots and small holes. looks like i will have to trim the front driprail edge middle section out. main thing is to be able to get the pinch weld solid,glass/gasket in, then seal it up across the top of gasket with body sealer.
ran out of wire today so add another 20$ for a 100$ total for patch repair.
still ahead at 450$ for rust free cab replacment.
Re: replacement cab. [Re: scratchnfotraction] #1470459
08/14/13 11:08 PM
08/14/13 11:08 PM
the rocker is next up for repair, my first rocker patch.
pretty solid exept for the holes. the 85 cab has 2 good solid rockers to chop away at.
