Re: Thoughts on engine vibration
[Re: Mopar_Mudder]
#1470273
07/24/13 11:19 AM
07/24/13 11:19 AM
Posts: 4,467 Morristown Tn.
71birdJ68
Morristown Tn.
Yea I think at this point I am going to pull the tranny and verify that the flywheel is sitting staight on the crank and has no run out. If that all looks good I will have to take it to someone and get it on a scope and see what we can see. I would just feel better knowing it is not something like the flywheel before I take it to someone.
I have a really old Snap On scope made for points, don't think that will do me much good, heck I don't even know how to use it.
Just so everyones on the same page, runout is for the bell housing not flywheel.
[Re: 71birdJ68]
#1470274
07/24/13 11:20 AM
07/24/13 11:20 AM
Posts: 75,126 A Banana Republic near you.
JohnRR
what he said ...
[Re: Mopar_Mudder]
#1470275
07/24/13 11:40 AM
07/24/13 11:40 AM
Posts: 167 maryland
74yellowduster
maryland
Vibration is thier with the clutch pushed in, it get worse with the clutch engauged and in neutral.
^^^ big hint right there ^^^
flywheel/pressure plate problem. could be a small burr or something between the flywheel & crank when it was bolted up.
[Re: 71birdJ68]
#1470276
07/24/13 01:08 PM
07/24/13 01:08 PM
Posts: 374 Wisconsin
Mopar_Mudder
Wisconsin
You can have run out on the flywheel if something would be between the crank surface and back of flyweel. Or if the flywheel hole would be slighly smaller then the end of the crank and not going on all the way. I don't know if runout is the correct term, but you know what I mean. That is what I am going to be looking for first, plan to start pulling it apart tonight.
[Re: Mopar_Mudder]
#1470278
07/26/13 12:01 PM
07/26/13 12:01 PM
JohnRR
Got it all apart last night and went to use my dial indicatior and it took a dump so I have to get a new one tonight. My clutch doesn't look good to me though, take a look here:
Bad Clutch ?
I don't think that has anything to do with your vibration.
[Re: JohnRR]
#1470279
07/26/13 12:06 PM
07/26/13 12:06 PM
Mopar_Mudder
Wisconsin
Bad Clutch ?
No I don't either, that is why I put it in a different thread, was just surprised to see it. New dial indicator tonight so I can when the flywheel and bell housing.
[Re: Mopar_Mudder]
#1470280
07/26/13 04:02 PM
07/26/13 04:02 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Where did the flywheel come from again?
[Re: Mopar_Mudder]
#1470281
07/26/13 04:07 PM
07/26/13 04:07 PM
Posts: 43,359 Bend,OR USA
Cab_Burge
Use the dial indicator to check the run out on the bellhousing register and , if you can, use it to check the mounting surface of the bellhousing in relationship to the flywheel face also ![](/ubbthreads/images/graemlins/thumbs.gif) . I can visualize what I want you to check but I'm not sure I can put that vision into words, here goes. I'm assuming your using a magnetic base for the dial indicator so put the base on the flywheel with the indictor sticking up through the input shaft hole in the bellhousing and put the stem of the indicator on the trans. mounting surface of the bell(face?), turn the motor over while watchig the indicator for up or down movement, it should be zero ![](/ubbthreads/images/graemlins/scope.gif) Lots of gremlins out thier ![](/ubbthreads/images/graemlins/rant.gif) They love messing with us racers and hot rodders ![](/ubbthreads/images/graemlins/shruggy.gif) Good luck, let us know what you find ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Cab_Burge]
#1470282
07/26/13 04:30 PM
07/26/13 04:30 PM
Mopar_Mudder
Wisconsin
Use the dial indicator to check the run out on the bellhousing register and , if you can, use it to check the mounting surface of the bellhousing in relationship to the flywheel face also . I can visualize what I want you to check but I'm not sure I can put that vision into words, here goes. I'm assuming your using a magnetic base for the dial indicator so put the base on the flywheel with the indictor sticking up through the input shaft hole in the bellhousing and put the stem of the indicator on the trans. mounting surface of the bell(face?), turn the motor over while watchig the indicator for up or down movement, it should be zero Lots of gremlins out thier They love messing with us racers and hot rodders Good luck, let us know what you find
I am in the process of that now, would have been done last night but my dial indicator took a dump.
[Re: Mopar_Mudder]
#1470283
07/26/13 05:46 PM
07/26/13 05:46 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I had to put a .006 shim between an original aluminum bell and the block to get mine within .002 = parallel of the flywheel. I wound up using Robmc offset dowels to dial in the concentricity, if you loosen the bolts once you have it dialed in, you will need to redo the whole measuring process. AMHIK....Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1470284
07/26/13 05:54 PM
07/26/13 05:54 PM
Mopar_Mudder
Wisconsin
That is one part I never figured out. I have heard multiple times that if you lossen the bell housing you have to do it again. Which makes sence because the dowels can not perfecty align the bell housing just do to the dowel having to be smaller then the hole to get it on. But yet you have to take the bell back off to get the clutch on, so how do you center it again which the clutch on ![](/ubbthreads/images/graemlins/whistling.gif)
[Re: Mopar_Mudder]
#1470285
07/26/13 08:07 PM
07/26/13 08:07 PM
JohnRR
and you still haven't ... ![](/ubbthreads/images/graemlins/laugh2.gif)
The original dowels are a slip fit so it will be close enough during a clutch change.
What the guy is talking about that you quoted is when you are dialing in the bell without the original dowels in the block. When you dial it in with the new dowels have the dowels in and lock them in place once you get intolerance runout and recheck after you lock them in. This is of course assuming you use the RobbMc dowels which are the ONLY dowels available that are the correct MOPAR size of .496 EVERYTHING else for sale by anyone , to dat that I know of , sell FORD .500 dowels as Mopar dowels, they are not.
[Re: JohnRR]
#1470286
07/26/13 10:22 PM
07/26/13 10:22 PM
Mopar_Mudder
Wisconsin
Well I didn't even look for any dowels when I put it together. I just made some quick on the lathe out of a 1/2" bar stock and turned them down until they fit, never gave it a second thought. But any way I just got done measuring stuff and this is what I got. The flywheel is with in .001 of being flat, square to the crank and round. The bell housing when checked for square to the block is within .005 Doing it my self so I was tuff to make sure the crank wasn't moving, I think the actual number may be lower then .005 Bell housing run out measurement I got: 12:00 .005 3:00 .001 6:00 .000 9:00 .003 So that is a run out of .0025, guess my home made dowels aren't to bad. So the good news is that I see nothing here that would cause a vibration. Bad news is I haven't found the issue yet ![](/ubbthreads/images/graemlins/confused.gif)
[Re: Mopar_Mudder]
#1470289
08/05/13 01:09 PM
08/05/13 01:09 PM
Mopar_Mudder
Wisconsin
Just wanted to update that I got the flywheel back, it was out of balance. So much for made in the USA new parts. In the attached picture the hole drilled on the right is how it came from the factory. The four on the left is what they drilled to get it balanced. Then they mounted the pressure plate and had to grind some off of spots on that to get it balanced. Engine is smoother now more inline with what I think it should be. Still have drive line stuff to work out though. ![](http://www.greenerslumber.com/cuda/clutch/IMG_1121.JPG)
