Ductile Iron Rocker/Valve Tip Alignment #1469827
07/18/13 02:49 PM
07/18/13 02:49 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
I'm not liking the way my rockers align on my exhaust valves, looking for some opinions.
These are Erson ductile irons. The picture below is the worst one. Intakes all look fine. Stock replacement rocket shafts with Hughes engines studded hold down kit. Should I just run a washer/shim between the exhaust rocker and the hold down? Am I missing something that is causing this issue?
Re: Ductile Iron Rocker/Valve Tip Alignment [Re: GTX MATT] #1469828
07/18/13 02:51 PM
07/18/13 02:51 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Another
Re: Ductile Iron Rocker/Valve Tip Alignment [Re: GTX MATT] #1469829
07/18/13 02:56 PM
07/18/13 02:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would shim it.. but I would also get rid of the
springs and shim everything to center them.. I made
up nylon style to shim it all.. I dont like a thin steel shim
that vibrates on the shaft and cuts it(sure it might
take a few years but it does).... JMO
EDIT
But it looks like your missing a washer on the one side
Re: Ductile Iron Rocker/Valve Tip Alignment [Re: MR_P_BODY] #1469830
07/18/13 03:13 PM
07/18/13 03:13 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Hey Mr P Body
The kit actually only came with washers to go between the springs/rockers, and from what I've seen usually people don't run any washers? Although I suppose the intent of the washers could have been to go between the rocker and hold down. There were no instructions, and this is what I've seen before when people do use washer if I recall correctly. My intake valves line up fine without anything between the hold down/rocker.
Re: Ductile Iron Rocker/Valve Tip Alignment [Re: GTX MATT] #1469831
07/18/13 03:31 PM
07/18/13 03:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You could use large washers(3/4") and cut down the OD
and get it very close... I try to stay with in .015
for some slop
Re: Ductile Iron Rocker/Valve Tip Alignment [Re: MR_P_BODY] #1469832
07/18/13 05:14 PM
07/18/13 05:14 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Personally, I like springs ... then you don't have the hassle of trying to get just the right clearance. I also figure if springs are good enough for virtually every Hemi rocker system, they're good enough for me !!!
Re: Ductile Iron Rocker/Valve Tip Alignment [Re: Stanton] #1469833
07/18/13 05:36 PM
07/18/13 05:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Your choice.. a SB pushes on a angle
Re: Ductile Iron Rocker/Valve Tip Alignment [Re: GTX MATT] #1469834
07/18/13 05:48 PM
07/18/13 05:48 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I prefer the shaft collars and I like to shim them. My 472 Hemi runs shaft collars and it cuts down the valvetrain noise I find. the last Isky BB rockers I setup had to be shimmed as well.
Sheldon
Re: Ductile Iron Rocker/Valve Tip Alignment [Re: GTX MATT] #1469835
07/18/13 06:25 PM
07/18/13 06:25 PM
I use VSI brand valve spring shims(probally motorcylce or small motor application) to position the rockers over the valve tips, sometimes I've even had to grind off some of the rocker arm sides to get them aligned and centered correclty
Re: Ductile Iron Rocker/Valve Tip Alignment [Re: GTX MATT] #1469836
07/18/13 06:36 PM
07/18/13 06:36 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Once you get the location squared away, you can take off some reciprocating weight by narrowing the tip from both sides to the same width as the stem diameter.
Boffin Emeritus
Re: Ductile Iron Rocker/Valve Tip Alignment [Re: Stanton] #1469837
07/18/13 06:39 PM
07/18/13 06:39 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
Me too. I made a set of spacers but every time I had the rockers off I had to check and reset the clearance. In the end I just re-fitted the springs.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: Ductile Iron Rocker/Valve Tip Alignment [Re: Mick70RR] #1469838
07/18/13 07:04 PM
07/18/13 07:04 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
well for what it is worth. Had springs on my for years. look to me you just need a shim between the hold down and the rocker.
Re: Ductile Iron Rocker/Valve Tip Alignment [Re: VernMotor] #1469839
07/18/13 09:15 PM
07/18/13 09:15 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
The Isky springs are too stiff IMHO You can get shims from Mancini Racing and spacers as well.I just took my heads and rockers over to Harland Sharp and they set me up on the spot
Gus
64 Plymouth Savoy
Dana 60
Re: Ductile Iron Rocker/Valve Tip Alignment [Re: fourgearsavoy] #1469840
07/18/13 09:33 PM
07/18/13 09:33 PM
Rittman Ohio
Rittman Ohio
I had a slight alignment issue as well that required some machining. It looks like all you have to do is move that shim from the spring and put it next to the hold down
Gus
64 Plymouth Savoy
Dana 60
