Re: Question on cleaning up a weld.
[Re: MidPenMopar]
#1469452
07/17/13 07:03 PM
07/17/13 07:03 PM
Posts: 1,392 Thayer, MO
bohmer2
Thayer, MO
I was wondering if it is possible to grind away the welds on my tailpipe tips so they look smoother.
If I just take my portable Mikita hand grinder and try to take off the rough area would that work or would I loosen the connection of the welds and cause the tips to break off??
Thanks for any advice. Stu
Any time a weld is ground there is the potential to weaken the connection.
That said, I personally think you could carefully grind down the weld based on the photo and make the weld look cleaner (less visible) without compromising it to the point the tips would break off.
[Re: GoodysGotaCuda]
#1469454
07/17/13 07:41 PM
07/17/13 07:41 PM
Posts: 36,840 South San Francisco, Californi...
MidPenMopar
Looking for fun? Keep looking
Pretty low resolution picture to try to show the area, but along with the above, use a "flapper" disc on the grinder. It leaves a much finer surface finish than a grinding stone.
Flapper disc? Is that like one I have that has pieces of fiber on it like a wire wheel?
This may be a little better of a photo of the welds.
[Re: MidPenMopar]
#1469457
07/17/13 08:41 PM
07/17/13 08:41 PM
Posts: 8,928 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Hmmm ... you wouldn't want to go posting this on any welding forums or they'd jump on you so fast it'd make your head spin. Any good weld (penetration) would not suffer from the bead being ground off.
As for this case, this isn't a bridge - go ahead and knock the bead off. Use the flap disk as previously recommended.
[Re: 340SHORTY]
#1469465
07/18/13 12:32 AM
07/18/13 12:32 AM
MidPenMopar
............... ![](/ubbthreads/images/graemlins/laugh2.gif)
Actually they are being replaced as we speak with a new under the car exhaust system. I got bored with the sidepipes so on to something completely different!
send me the side pipes..
I am giving them to a young man who is building his first hot rod and does not have much money for parts. So it's my way of helping him out and getting him on the road sooner.
