Question on cleaning up a weld. #1469451
07/17/13 06:37 PM
07/17/13 06:37 PM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
I was wondering if it is possible to grind away the welds on my tailpipe tips so they look smoother.
If I just take my portable Mikita hand grinder and try to take off the rough area would that work or would I loosen the connection of the welds and cause the tips to break off??
Thanks for any advice.
Stu
Re: Question on cleaning up a weld. [Re: MidPenMopar] #1469452
07/17/13 07:03 PM
07/17/13 07:03 PM
Thayer, MO
bohmer2 Offline
bohmer2  Offline
Thayer, MO
Stu
Any time a weld is ground there is the potential to weaken the connection.
That said, I personally think you could carefully grind down the weld based on the photo and make the weld look cleaner (less visible) without compromising it to the point the tips would break off.
Re: Question on cleaning up a weld. [Re: bohmer2] #1469453
07/17/13 07:23 PM
07/17/13 07:23 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Pretty low resolution picture to try to show the area, but along with the above, use a "flapper" disc on the grinder. It leaves a much finer surface finish than a grinding stone.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Question on cleaning up a weld. [Re: GoodysGotaCuda] #1469454
07/17/13 07:41 PM
07/17/13 07:41 PM
Flapper disc? Is that like one I have that has pieces of fiber on it like a wire wheel?
This may be a little better of a photo of the welds.
Re: Question on cleaning up a weld. [Re: MidPenMopar] #1469455
07/17/13 07:43 PM
07/17/13 07:43 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Flapper for a 4-1/2" grinder
2020 RAM 1500
Re: Question on cleaning up a weld. [Re: GoodysGotaCuda] #1469456
07/17/13 08:07 PM
07/17/13 08:07 PM
Ok Mike thanks for the idea! I will try that first!
Re: Question on cleaning up a weld. [Re: MidPenMopar] #1469457
07/17/13 08:41 PM
07/17/13 08:41 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Hmmm ... you wouldn't want to go posting this on any welding forums or they'd jump on you so fast it'd make your head spin. Any good weld (penetration) would not suffer from the bead being ground off.
As for this case, this isn't a bridge - go ahead and knock the bead off. Use the flap disk as previously recommended.
Re: Question on cleaning up a weld. [Re: MidPenMopar] #1469458
07/17/13 08:41 PM
07/17/13 08:41 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
what happened to the sidepipes?? I like them much better..
I am truckless..
Re: Question on cleaning up a weld. [Re: 340SHORTY] #1469459
07/17/13 08:45 PM
07/17/13 08:45 PM
They are still on there.....Just now go out the back!
Re: Question on cleaning up a weld. [Re: MidPenMopar] #1469460
07/17/13 08:49 PM
07/17/13 08:49 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: Question on cleaning up a weld. [Re: 340SHORTY] #1469461
07/17/13 08:52 PM
07/17/13 08:52 PM
Actually they are being replaced as we speak with a new under the car exhaust system. I got bored with the sidepipes so on to something completely different!
Re: Question on cleaning up a weld. [Re: MidPenMopar] #1469462
07/17/13 09:13 PM
07/17/13 09:13 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Re: Question on cleaning up a weld. [Re: OzHemi] #1469463
07/17/13 09:41 PM
07/17/13 09:41 PM
The Larch, the larch.....
Re: Question on cleaning up a weld. [Re: MidPenMopar] #1469464
07/17/13 10:20 PM
07/17/13 10:20 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
send me the side pipes..
I am truckless..
Re: Question on cleaning up a weld. [Re: 340SHORTY] #1469465
07/18/13 12:32 AM
07/18/13 12:32 AM
I am giving them to a young man who is building his first hot rod and does not have much money for parts. So it's my way of helping him out and getting him on the road sooner.
Re: Question on cleaning up a weld. [Re: MidPenMopar] #1469466
07/18/13 01:59 AM
07/18/13 01:59 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: Question on cleaning up a weld. [Re: 340SHORTY] #1469467
07/18/13 08:02 AM
07/18/13 08:02 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Or this:
Re: Question on cleaning up a weld. [Re: MidPenMopar] #1469468
07/18/13 08:21 AM
07/18/13 08:21 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I personally would not grind it. it'll just draw more attention to the pipe. You will never get it better than it is now, ginding it will just make it stand out more unless your the welder.
Your have grind marks to look at instead of a weld bead.
Re: Question on cleaning up a weld. [Re: Challenger 1] #1469469
07/18/13 08:51 AM
07/18/13 08:51 AM
Hummmn?? Don't want that for sure.....
Re: Question on cleaning up a weld. [Re: MidPenMopar] #1469470
07/18/13 10:24 AM
07/18/13 10:24 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
and wouldn't the ground areas rust up quicker?
