MOTOR HOME CRANKS #1469018
07/16/13 09:22 PM
07/16/13 09:22 PM
NEW HAMPSHIRE AND MAINE
BIGSTROKER Offline OP
DOES ANYBODY KNOW IF ALL MOTOR HOMES 440'S CAME WITH STEEL CRANKS
Re: MOTOR HOME CRANKS [Re: BIGSTROKER] #1469019
07/16/13 09:25 PM
07/16/13 09:25 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
MOST ... but not all. What does the dampner look like ?
Re: MOTOR HOME CRANKS [Re: dOOc] #1469020
07/16/13 09:34 PM
07/16/13 09:34 PM
DON'T ASKING FOR A FRIEND I TOLD HIM TO LOOK AT THE DAMPER
Re: MOTOR HOME CRANKS [Re: BIGSTROKER] #1469021
07/17/13 12:14 AM
07/17/13 12:14 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Dump the caps.. Some of us dont like being yelled at.
I am truckless..
Re: MOTOR HOME CRANKS [Re: 340SHORTY] #1469022
07/17/13 12:44 AM
07/17/13 12:44 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
A motorhome 440 with a steel crank, I don't think so
74 was the first year the 440 was listed for MH use
On the other hand MH 413 uses a steel crank & rods comparable to the 440+6 with the only difference being bobwieght as it appears
Re: MOTOR HOME CRANKS [Re: BulletBob] #1469023
07/17/13 01:21 AM
07/17/13 01:21 AM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
I have a 1974 Travco with a steel crank 440 in it ...also a friend has a 1975 ...same same .....
Re: MOTOR HOME CRANKS [Re: dOOc] #1469024
07/17/13 01:42 AM
07/17/13 01:42 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
My 73' 270 had a 413 steel & the 75' 270 that replaced it had a cast 440
I love Travcos too! Ahead of their time!
Re: MOTOR HOME CRANKS [Re: BulletBob] #1469025
07/17/13 02:12 AM
07/17/13 02:12 AM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
My 73 Discoverer has a bone-stock 413 in it ....to be eventually replaced by a 2014 413 ! The 74 220 Travco will .. if I keep it .... will have the same "2014" 413 ...
Re: MOTOR HOME CRANKS [Re: BIGSTROKER] #1469026
07/17/13 03:09 AM
07/17/13 03:09 AM
1974 was a transition year for Dodge going from the H.D. 413 motors in the larger M.H. and trucks to the 440-3 motors in the same year and chassis units. I've seen forged steel cranks with the H.D. six pak rods in 440-3 cast blocks and assembled in 1974 I've also seen the same series motors with cast cranks and dampeners in 1974 vehicles
Re: MOTOR HOME CRANKS [Re: BulletBob] #1469027
07/17/13 12:36 PM
07/17/13 12:36 PM
Indiana
Mrbill69 Offline
Mrbill69  Offline
Indiana
My 73 Winny might have been a late one for 73 but it had a steel crank 440 with timing gears and a thermoquad. Sounded like it had a blower.
66 satellite conv w/413, cam & headers, 3.55 gears. 89 Dodge w150 4x4 318 Tbi. Opec's friend 72 Imperial coupe
Re: MOTOR HOME CRANKS [Re: Mrbill69] #1469028
07/17/13 09:12 PM
07/17/13 09:12 PM
Middletown , Ohio
DonnieLawson Offline
Middletown , Ohio
My 73 440 was from a Motor Home , it had a steel crank and 6 pak rods ,now its a 505 stroker motor for my 68 Barracuda:)
The 78 440 in my Rat Rod is a motor home engine also , but has a cast crank
