Door plastic vapor barriers #1468211
07/15/13 01:06 PM
07/15/13 01:06 PM
Ont, Canada
gygeneral Offline OP
Ont, Canada
What product are you guys using to install the plastic liner behind our door panels. The original stuff was like a white calk. I know 3M sells a black calk but hter must be something out there.
Re: Door plastic vapor barriers [Re: gygeneral] #1468212
07/15/13 04:28 PM
07/15/13 04:28 PM
cbusters Offline
cbusters  Offline
You can get/order it from Ace Hardware, along with the tape.
Re: Door plastic vapor barriers [Re: gygeneral] #1468213
07/15/13 04:44 PM
07/15/13 04:44 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I just got the thickest roll of plastic I could find, then I took 3M spray adhesive and sprayed the high spots stuck it to it and trimmed when dry. Works out kinda neat.
Re: Door plastic vapor barriers [Re: gygeneral] #1468214
07/15/13 05:34 PM
07/15/13 05:34 PM
Iowa
burdar Online work
Owen's Dad
burdar  Online Work
Owen's Dad
Iowa
DMT has a white strip caulk they include with the heater box kits. I'd call and ask them about it.
Re: Door plastic vapor barriers [Re: gygeneral] #1468215
07/15/13 05:48 PM
07/15/13 05:48 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I bought some precut barriers on e bay that came with a gray caulk. Just did a google search and can only find the previous 3M black and this stuff from Eastwood:
http://www.eastwood.com/ew-flexible-stri...CFYdxQgod4iUAPQ
I have had good luck with all 3M products.
BTW, the electricians I work with call the stuff dum dum.
Craig
Re: Door plastic vapor barriers [Re: burdar] #1468216
07/15/13 11:43 PM
07/15/13 11:43 PM
cbusters Offline
cbusters  Offline
The box has Ace Hardware on it.
Re: Door plastic vapor barriers [Re: gygeneral] #1468217
07/15/13 11:55 PM
07/15/13 11:55 PM
IL,USA
bdusted440 Offline
bdusted440  Offline
IL,USA
What product are you guys using to install the plastic liner behind our door panels. The original stuff was like a white caulk. I know 3M sells a black caulk but hter must be something out there.
It's actually called butyl tape. The big three have been using it for 60 years.
Re: Door plastic vapor barriers [Re: bdusted440] #1468218
07/16/13 12:15 AM
07/16/13 12:15 AM
Ont, Canada
Ont, Canada
Thanks everyone for all the ideas, I will follow up tomorrow. I sent an email to DMT already.
Re: Door plastic vapor barriers [Re: gygeneral] #1468219
07/17/13 06:30 PM
07/17/13 06:30 PM
Utah
E
Eagleone1983 Offline
E
Utah
Amazon sells the 3m black strip caulking. I used that and the thickest plastic sheeting I could find at Lowe's. The part number for the 3m stuff is 08578
Re: Door plastic vapor barriers [Re: Eagleone1983] #1468220
07/18/13 08:12 AM
07/18/13 08:12 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Re: Door plastic vapor barriers [Re: Dave Watt] #1468221
07/18/13 03:41 PM
07/18/13 03:41 PM
Ont, Canada
Ont, Canada
Thanks everyone I ended up using the 3M stuff.
