PRW rocker arms #1467255
07/13/13 02:21 PM
07/13/13 02:21 PM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
I have been looking at the stainless, silicon bronze bushed 1.6 rockers for a big block.
Junk?
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: PRW rocker arms [Re: old_goat] #1467256
07/13/13 02:58 PM
07/13/13 02:58 PM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
84 D150 440/727
79 /6 swb D150
Re: PRW rocker arms [Re: old_goat] #1467257
07/13/13 07:20 PM
07/13/13 07:20 PM
Southern CA
Colin Frolick Offline
Southern CA
Been running the steel 1.6 ratio arms on this 493 for 5 years, probably 15k miles. haven't touched them since i put the motor together. I think they are nice.
I spent alot of time with the shims to center them on the valves, as in this photo.
Re: PRW rocker arms [Re: old_goat] #1467258
07/13/13 09:52 PM
07/13/13 09:52 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Brian of IMM recommends them, he's putting a set on the motor he's building for me.
Re: PRW rocker arms [Re: Skeptic] #1467259
07/14/13 12:29 AM
07/14/13 12:29 AM
Southern CA
Southern CA
Hey IMM built the shortblock on that one ^ runs like a champion!
Re: PRW rocker arms [Re: Colin Frolick] #1467260
07/14/13 02:40 AM
07/14/13 02:40 AM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
Thanks guys! I thought they looked like ok units bein bronze bushed, also like the fact they have cup style adjusters.
Glad to have good feedback!
Bill
84 D150 440/727
79 /6 swb D150
Re: PRW rocker arms [Re: old_goat] #1467261
07/14/13 08:56 AM
07/14/13 08:56 AM
Amherst,NY
challengermike Offline
Amherst,NY
They do have some problems though. Make sure you check that the body of the rocker doesn't hit the valve stem. I had to grind mine to fit . Also after about 1,000 miles my set started having the adjusters loosen up. It happened 3 times and I had to replace the adjusters with Harland sharp ones. But For the price of the link you posted you could buy a better set of rockers. I paid only $225 off ebay for my set. Also the prw rockers are really cat rockers.
Re: PRW rocker arms [Re: old_goat] #1467262
07/14/13 09:18 AM
07/14/13 09:18 AM
Norrland, Sweden
Swedcharger67 Offline
Norrland, Sweden
I didn't like them. They looked good but the adjusters were loose in the threads and the threads didn't give a quality feel.
I decided to not use them in my engine.
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
