Carter carb question #1465514
07/09/13 06:34 PM
07/09/13 06:34 PM
Newberry Springs, CA
69Mannix Offline OP
69Mannix  Offline OP
Have a used afb on a 340 with purple shaft in a ramcharger. Have to keep the rpm up that it will not stall in gear. Have to keep it in gear to keep from dieseling when shutting down. Is there a fix for this? Thanks
Re: Carter carb question [Re: 69Mannix] #1465515
07/09/13 07:48 PM
07/09/13 07:48 PM
What's your initial? More (15-20) may help with both. I'm assuming you've opened the idle mix screws to no avail. How many turns is the idle speed screw opened from the throttle just closed position
Re: Carter carb question [Re: RapidRobert] #1465516
07/09/13 11:12 PM
07/09/13 11:12 PM
69Mannix Offline OP
69Mannix  Offline OP
I wanted to ask first, the throttle screw is 2 1/2 turns from close.
Re: Carter carb question [Re: 69Mannix] #1465517
07/10/13 05:49 PM
07/10/13 05:49 PM
69Mannix Offline OP
69Mannix  Offline OP
btt
Re: Carter carb question [Re: 69Mannix] #1465518
07/11/13 12:55 AM
07/11/13 12:55 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Throttle screw? As in, to set the idle?
What about the two mixture screws on the front of the carb?
Make sure the transition slot is not exposed. If your throttle blades are letting a little air get through there you will have problems tuning it.
- Stu Harmon
Re: Carter carb question [Re: feets] #1465519
07/11/13 01:52 AM
07/11/13 01:52 AM
69Mannix Offline OP
69Mannix  Offline OP
Have adjusted the mixture screws, but not sure about transition slot?
Re: Carter carb question [Re: 69Mannix] #1465520
07/11/13 02:00 AM
07/11/13 02:00 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
which purple shaft cam?
remove the caps off the metering rods...start engine and watch metering rods...are they sucked down into the jet?...or bouncing up and down...?
if the answer is yes...you need to change the step spring to lighter one to allow the metering rods to sit down into the jets while idling.
Tony
70 AARCuda Vitamin C
Re: Carter carb question [Re: 70AARcuda] #1465521
07/11/13 03:31 AM
07/11/13 03:31 AM
Especially in gear, have someone start the motor up after it is warmed up and then check the metering rods, if there not sucked down into the jets trim or replace those springs under the pistons on the metering rods so they do stay down in gear idling
Re: Carter carb question [Re: RapidRobert] #1465522
07/11/13 12:58 PM
07/11/13 12:58 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
This!
Re: Carter carb question [Re: RobX4406] #1465523
07/11/13 04:19 PM
07/11/13 04:19 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
With the car idling loosen the metering rod covers and swing them aside. Are the pistons and rods dancing up and down, or possibly just up. If so the metering rod springs are to stiff. It would be like a Holley with the power valve open at idle. Edelbrock makes springs that you can adapt. My race car idles with Edelbrocks with a 285@.050" cam with no issue.
Doug
