Line Locks #1465064
07/08/13 10:44 PM
07/08/13 10:44 PM
Kent, Wa
340SHORTY Offline OP
Truck Nut
Truck Nut
Kent, Wa
Im considering installing a Line Lock on my shorty with the OD833. Not to be used for burnouts but as a hill holder. We have some fairly steep hills with stoplights around here. Do any of you guys have 1 on your truck. What brand. Where did you mount it? Im thinking about a bracket that uses the 2 master cylinder/booster studs for mounting. I hve a 2 spoke steering wheel with the holes in it so I will mount the button in the left outer most hole for activation..
I am truckless..
Re: Line Locks [Re: 340SHORTY] #1465065
07/08/13 11:37 PM
07/08/13 11:37 PM
Milwaukee, WI
Prince_Valiant Offline
Milwaukee, WI
I would try to install the the line lock button on the shifter if it's primarily for hill holding...jmo.
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
Re: Line Locks [Re: Prince_Valiant] #1465066
07/08/13 11:45 PM
07/08/13 11:45 PM
Kent, Wa
Truck Nut
Truck Nut
Kent, Wa
I cant think of any easy way to mount it on a Pistol Grip shifter that would be easy to operate., a normal shifter no problem..
I am truckless..
Re: Line Locks [Re: 340SHORTY] #1465067
07/09/13 01:04 PM
07/09/13 01:04 PM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
Putting the button in the wheel will be a pain.I know.Had it there on my 65.Every time you make a turn it wraps around the TS arm.It finally broke the wire at the button.I had a plate made up for my Pistol grip.It worked but was a pain to power shift.With the stock stick its easy to attach.My lock is mounted at my master.Been there for 5 or 6 years and no problems.Rocky
Chrysler Firepower
Re: Line Locks [Re: therocks] #1465068
07/09/13 07:55 PM
07/09/13 07:55 PM
Kent, Wa
Truck Nut
Truck Nut
Kent, Wa
Pics ?
I am truckless..
Re: Line Locks [Re: 340SHORTY] #1465069
07/09/13 08:05 PM
07/09/13 08:05 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Just build a bracket so the switch isnt attached to the wheel but behind it in a spot you can reach with your thumb yet clears when turning
Re: Line Locks [Re: 76dodgeboy] #1465070
07/10/13 09:04 AM
07/10/13 09:04 AM
Niles , Ohio
Niles , Ohio
I tossed the bracket I made for my PG.Its buried in the garage somewhere.Ive thought about getting one of the Hurst PGs with the button and retapping it to fit my stock 65 stick.Someone was supposed to make a top with button for the factory PG.Ive been looking for one for years.That would be the ticket.Rocky
Chrysler Firepower
Re: Line Locks [Re: therocks] #1465071
07/12/13 09:46 AM
07/12/13 09:46 AM
Chicagoland
stacks79 Offline
stacks79  Offline
Chicagoland
I put a hurst roll control in my RC. Put it on the back of the engine crossmember (4wd has the line coming down right there). Can't recall if 2wd has same brake line placement. Also purchased the hurst t handle shifter with button. Several shift knobs have switches built in. Easiest for what you want to do IMO
John
Re: Line Locks [Re: stacks79] #1465072
07/12/13 05:13 PM
07/12/13 05:13 PM
Kent, Wa
Truck Nut
Truck Nut
Kent, Wa
Kinda impossible to put a round shifter ball on a Pistol Grip shifter..
I am truckless..
Re: Line Locks [Re: 340SHORTY] #1465073
07/16/13 02:14 AM
07/16/13 02:14 AM
libby mt
lifted85 Offline
lifted85  Offline
libby mt
hey 340 shorty what if ya add a floor switch? or if you don't have a horn, use your horn as the button seen it done in a old skylark.
drive fast, drive hard, DRIVE MOPAR
Re: Line Locks [Re: lifted85] #1465074
07/16/13 02:57 AM
07/16/13 02:57 AM
Kent, Wa
Truck Nut
Truck Nut
Kent, Wa
Cant use the horn button.. It goes BeepBeep when you push the button twice..
I am truckless..
Re: Line Locks [Re: 340SHORTY] #1465075
07/16/13 04:55 AM
07/16/13 04:55 AM
libby mt
lifted85 Offline
lifted85  Offline
libby mt
you don't say... if you had after market wheel an you did not hook the horn up.. it wouldn't be hard to build a bracket that connect's to the column an bend's up with a push button on it kind of like a paddle shifter ya know?? just some idea's
Re: Line Locks [Re: lifted85] #1465076
07/17/13 12:23 AM
07/17/13 12:23 AM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
I have used a micro switch from radio shack attached to the shifter stem just under the handle with a home made bracket. I used my pinky finger to operate it. I used coiled wire down to the boot, and then under the carpet to the solenoid and power source.
My
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: Line Locks [Re: old_goat] #1465077
07/17/13 01:41 AM
07/17/13 01:41 AM
Kent, Wa
Truck Nut
Truck Nut
Kent, Wa
I have a new Comp Plus shifter but my Pistol Grip is the push in style and the new 1 is the bolt on style. I dont really want to drill the holes in the PG but if push comes to shove The new handle has the same bend as the factory 1 but nowhere near the class of the PG..
I am truckless..
