New MP electronic distributor setup #1464448
07/07/13 11:37 PM
07/07/13 11:37 PM
MN
mnguy55 Offline OP
mnguy55  Offline OP
MN
I'm installing a MP electronic kit I bought back in 2005 in my otherwise all stock 70 Charger RT 440. I also bought the spring/key kit that works with this unit too. Any suggestions on switching springs to something other than the stock settings on the distributor before I put it on the car?
Re: New MP electronic distributor setup [Re: mnguy55] #1464449
07/07/13 11:47 PM
07/07/13 11:47 PM
I'd find the initial YOUR eng wants with the "vacuum gauge" method then with that number in hand use the keys to set the total (initial+keys) to 36. then springs then plug in/adj the vac adv.
