Crush Can Turn Signal Cancel Lever #1463049
07/05/13 01:10 PM
07/05/13 01:10 PM
Wisconsin
Mopar_Mudder Offline OP
Wisconsin
Would anyone have anything that says what direction the heavy wire snap ring on the back of the crush can is suppose to face to properly cancel the turn signal?
1971 Hemi Cuda 2005 SRT-10 Regular Cab Flame Red. 12.771 @ 109.67<---TIME SLIP--Video
Re: Crush Can Turn Signal Cancel Lever [Re: Mopar_Mudder] #1463050
07/05/13 06:12 PM
07/05/13 06:12 PM
1970_EK2AAR Offline
1970_EK2AAR  Offline
I don't have a photo, but looking at the copper ring from the backside, the wire routes thru one of the holes and the "cancel tab" is positioned directly across (180) from it.
Re: Crush Can Turn Signal Cancel Lever [Re: 1970_EK2AAR] #1463051
07/05/13 06:15 PM
07/05/13 06:15 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
Does this help?
Ola
1970 `cuda340 convertible 4-speed Rallye Red with Red interior
cudaized.com
1970-71 Plymouth and Dodge E-Body Convertible Registry
ebodyconvertibleregistry.com
Re: Crush Can Turn Signal Cancel Lever [Re: cudaized] #1463052
07/05/13 06:23 PM
07/05/13 06:23 PM
Wisconsin
Wisconsin
That is perfect, thank you.
Looks like it is at 3:00 from the flat spot. I set mine at 9:00 which would be why it isn't working right, will change it tonight.
Re: Crush Can Turn Signal Cancel Lever [Re: Mopar_Mudder] #1463053
07/05/13 06:30 PM
07/05/13 06:30 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
You are welcome.
Ola
Re: Crush Can Turn Signal Cancel Lever [Re: cudaized] #1463054
07/09/13 04:01 PM
07/09/13 04:01 PM
Wisconsin
Wisconsin
Just wanted to update that after turning the spring clip to the correct position the turn signal cancels perfect now, one more problem sovled.
