lower control arm pics #146203
11/05/08 09:23 PM
11/05/08 09:23 PM
Canada
sassysixpack1 Offline OP
Canada
Anyone have any good pics of their restored (cosmoline look) lower control arms?
Thanks!!
Re: lower control arm pics [Re: sassysixpack1] #146204
11/05/08 09:36 PM
11/05/08 09:36 PM
Oakville.ON,Canada
hemi_rtdave Offline
hemi_rtdave  Offline
Oakville.ON,Canada
These are dipped in actaul cosmoline.
Re: lower control arm pics [Re: sassysixpack1] #146205
11/05/08 09:37 PM
11/05/08 09:37 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Here's an older pic showing the dipping line on the control arm sprayed with Eastwood's heavy duty anti-rust...
Re: lower control arm pics [Re: hemi_rtdave] #146206
11/05/08 09:37 PM
11/05/08 09:37 PM
Oakville.ON,Canada
hemi_rtdave Offline
hemi_rtdave  Offline
Oakville.ON,Canada
Another
Re: lower control arm pics [Re: screamindriver] #146207
11/05/08 10:21 PM
11/05/08 10:21 PM
Dallas, TX
70challrtse Offline
super gas
70challrtse  Offline
super gas
Dallas, TX
Here's a pic of a unrestored arm showing the original dip line after cleaning it up a bit.
Re: lower control arm pics [Re: 70challrtse] #146208
11/06/08 12:18 AM
11/06/08 12:18 AM
Soldotna,Alaska
RT_6_PakShaker Offline
super street
super street
Soldotna,Alaska
another pic of lower arm dipped in cosmoline
Re: lower control arm pics [Re: RT_6_PakShaker] #146209
11/06/08 08:20 AM
11/06/08 08:20 AM
MO
cdp Offline
cdp  Offline
MO
any hints as to the process of restoration? I have my a12's suspension tore down and was thinking of having the LCA's powdercoated with a light cast gray finish, then add the cosmoline.
I can't think of a way to get the really nice smooth "as stamped" look after all the years of wear and tear. Bead blasting and stripping seems to ruin the original smooth finish. Would love to here someones process of restoration for both the Upper and Lower control arms.
Re: lower control arm pics [Re: sassysixpack1] #146210
11/06/08 09:11 AM
11/06/08 09:11 AM
Canada
Canada
Thanks for the pics guys, it helps a lot!!
Re: lower control arm pics [Re: cdp] #146211
11/06/08 10:26 PM
11/06/08 10:26 PM
New England
Q5_Ed Offline
Q5_Ed  Offline
New England
Start another post with Upper and Lower Control Arm Restoration on here and the A12 Forum! My
I'm interested as well. Anybody restoring them for people out there?
WANTED : ...A New Sponsor or Winning Lottery Ticket 69 A12 road runner ,Q5, post coupe, 4 speed, former Drag car restored to "Driver" condition in the early 90's, Showing some Patina. SS/E Track Record Holder 1980 10.40 @ 130mph
Re: lower control arm pics [Re: Q5_Ed] #146212
11/06/08 11:48 PM
11/06/08 11:48 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
....NOS arm.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: lower control arm pics [Re: Troy] #146213
11/07/08 11:43 AM
11/07/08 11:43 AM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Restored arm using VHT Epoxy Stainless Steel & Kyrlon Battery Protector.
Re: lower control arm pics [Re: cdp] #146214
11/07/08 02:01 PM
11/07/08 02:01 PM
midwest
sg333e Offline
super street
sg333e  Offline
super street
midwest
That is exactly what I did, I'll try to post a pic over the weekend.
Hobbies and associated message boards: 1970 Cuda 440+6 FE5 H6X9 4 SP> Moparts.com 1987 Grand National (422rwhp/566tq)> TurboBuick.com 2008 BMW 335 TT 6MT> E90Post.com 2008 Gary Fisher HiFi Plus 29er > MTBR.com 2008 German Shorthair Pointer > Shorthairs.net
Re: lower control arm pics [Re: sg333e] #146215
11/07/08 07:54 PM
11/07/08 07:54 PM
MO
cdp Offline
cdp  Offline
MO
Thanks Rayztoy for that pic. and the other info. This will help greatly.
Re: lower control arm pics [Re: 70challrtse] #146216
11/08/08 11:18 PM
11/08/08 11:18 PM
What's a good finish for parts that were originally left bare, like the UCAs, LCA strut rods, drag link, etc?
Re: lower control arm pics [Re: sassysixpack1] #146217
11/08/08 11:26 PM
11/08/08 11:26 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Thanks!!
If your looking for real cosmoline, sprayable in a spraycan PM me
Re: lower control arm pics [Re: cdp] #146218
11/09/08 09:19 AM
11/09/08 09:19 AM
North Carolina, USA
Silverbullet2 Offline
North Carolina, USA
I like to go over my parts with a wire wheel after sandblasting. It seems to take the haze or matte finish off and cast or even stamped parts look almost factory fresh.
I cheated a little on the LCAs finish. The ex left a spray can of "24 karat" gold paint. I dusted them with that and then a coat or two of krylon clear (Also courtesy of the ex...). I haven't added the dip line yet but I'm planning to. I figure they're protected and they look identical to some of the ones I see here.
Re: lower control arm pics #146219
11/09/08 10:44 PM
11/09/08 10:44 PM
Harrisburg, Pa.
Harrisburg, Pa.
Hey, I see this is your first post !! Welcome to the board.. ... If you're going the painted route a "stainless steel" color is a good base coat....Seymour makes a stainless color with real stainless metal in it...Another choice is VHT all-weather epoxy...That's the one I prefer...It's a little darker than the Seymour paint....When you spray the stainless paint go for the coverage on the first coat then mist-coat the part for the rougher texture and drier look.....Now, here's the real trick on getting the painted components to look different from each other....Use the stainless as the base then mist-coat a darker color over it...Then use a scotch-brite pad to hit the highlights of the part...Check out this spindle assy for a 73 road runner...It was done using the VHT stainless epoxy then mist-coated with Eastwood's Black phosphate...... Click on the attachment for the bigger view...
Re: lower control arm pics [Re: screamindriver] #146220
11/09/08 11:59 PM
11/09/08 11:59 PM
Thanks, I wandered in here while searching for suspension pictures. I'm working on a '70 Cuda that I bought 15 years ago. The body has been hanging on a rotisserie for a while now laid up in primer. The neighborhood body shop is going to do the paint and I'm fiddling with the suspension right now. I was curious what other people were using for suspension finishes. Here is a photo of some parts I did today. I degreased them in bucket of Castrol Super Clean and then derusted them in a bucket of muriatic acid. I rinsed with baking soda and water, blew them off with the compressor and shot them with Eastwood Diamond Clear. They turned out pretty well. The acid does a pretty good job without fracturing and frosting the surface like blasting does. They aren't perfect, with variations in color here and there, but they are clean and protected with a little character...
Re: lower control arm pics #146221
11/10/08 09:17 AM
11/10/08 09:17 AM
Southeastern MI.
Q
QuickSilver Offline
mopar addict
QuickSilver  Offline
mopar addict
Q
Southeastern MI.
As a fellow Texan myself,Welcome aboard their mmccarty. Here are a couple pics of some stuff that I am doing in my shop. Going for that perfect look while using no spray paint products,only properly prepared base metal. There is a difference! The lower arms are bare metal with only true cosmoline to cover. The upper control arms are prepped the same way. Actually a little different product used on them so that all of the parts have a slightly different look.
Re: lower control arm pics [Re: QuickSilver] #146222
11/10/08 09:19 AM
11/10/08 09:19 AM
Southeastern MI.
Q
QuickSilver Offline
mopar addict
QuickSilver  Offline
mopar addict
Q
Southeastern MI.
Another:
