Why does my 92 Dakota ex cab, short box have 2 piece? #1461514
07/01/13 10:22 PM
07/01/13 10:22 PM
State of Confusion
hp383 Offline OP
Just a normal tag again
hp383  Offline OP
State of Confusion
My 92 Dak, it is a 2wd, extended cab, short box, has a two piece driveshaft with the CV joint.
Why was this done? I'm almost positive that my standard cad D100 long box drive shaft is no longer than this two piece design.
I am giving some thought to having my one piece measured and shortened if needed to fit into the Dak. But was curious as to why they made such a short truck with a two piece design.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Why does my 92 Dakota ex cab, short box have 2 piece? [Re: hp383] #1461515
07/01/13 10:27 PM
07/01/13 10:27 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Because the engineers know more than we do.
I am truckless..
Re: Why does my 92 Dakota ex cab, short box have 2 piece? [Re: 340SHORTY] #1461516
07/02/13 12:31 AM
07/02/13 12:31 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Maybe the driveshaft angles are too tight for a single shaft?
Gene
Re: Why does my 92 Dakota ex cab, short box have 2 piece? [Re: poorboy] #1461517
07/02/13 01:57 AM
07/02/13 01:57 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
the shaft would fall below the plane of the frame too far forward to clear obstacles most likely.
I did a 1 piece in a S10 Ex cab once & hi centered it at a point where the frame should sit solid & barely the exhaust pipe would touch
I found out immediately what else was dragging in the dirt when I got out on the road about 25 MPH
Had a small dent with an oval shaped swell around it at the point where it broke the plane of the frame about a foot ahead of where the two piece joined
One piece works good on Drag trucks that don't get as daily drivers
Re: Why does my 92 Dakota ex cab, short box have 2 piece? [Re: hp383] #1461518
07/03/13 12:12 AM
07/03/13 12:12 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Are you sure it has a cv joint??? Never saw one with a cv joint. Two piece with a center bearing yes.
