Re: can i make my dodge shadow handle?
[Re: ogopogo]
#1460083
06/29/13 11:31 PM
06/29/13 11:31 PM
Posts: 96,664 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Lowering if you want but the thing it REALLY NEEDS is an anti-sway bar, maybe only in the front, but maybe one in the rear also.
Lowering and stiffer coils won't remove all that much roll. Stiffer coils will help to keep the outside on a turn from going down, but they will also help PUSH UP the inside on a turn, so the roll is still there. Anti-sway bar is what you want, matched to the coils and shocks.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: jcc]
#1460085
06/30/13 10:42 AM
06/30/13 10:42 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Had an 86 Daytona, which I bought new. Same basic chassis as your Shadow.
Good tires, lowering springs, good shocks and struts, bigger front bar, added a rear bar and it handled very well. I believe I used Suspension Techniques springs and bars and I cannot remember what dampers anymore. Doesn't look like ST does Mopar stuff, unless it's captive imports.
