Re: Indy Tunnel Ram Top Plate Version Info
[Re: Jeremiah]
#1459824
06/29/13 10:26 AM
06/29/13 10:26 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Don't know if this will help you but my Indy tunnel Ram for a 440 has 12 bolts holding the top plate on. If you need some pictures let me know.
[Re: pittsburghracer]
#1459825
06/29/13 10:36 AM
06/29/13 10:36 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Current 4150 style. I think the 22 bolt was a good 7 or 8 yuears ago.
RIP Monte Smith
#1459827
06/29/13 11:58 AM
06/29/13 11:58 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
Put you some 4150-4500 adapter plates on it,use your drummel to make sure you match the bottom of the spacer to the top of the intake(gasket match them to each other).They tell me adding a spacer to the Indy intake is worth a few extra horse-power as well.I was going to test a few different thickness spacers a while back,but due to the cost of having to buy 2 of each and I was told running mech.FI I would not see the benfits as with carbs.I never got around to it. PS You will get 2 for the price of 1 an adapter to mate your carb. to the intake and a spacer which will increase your perfomance! Double PS,most of the single Indy intakes use a super sucker,so there is nothing wrong or bad about running an adapter plate.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: Jeremiah]
#1459829
06/29/13 03:38 PM
06/29/13 03:38 PM
Posts: 9,102 Rogue River, OR
Jeremiah
Rogue River, OR
Shoot...here is another option: http://www.ebay.com/itm/1-5-INCH-CARB-AD...2f3&vxp=mtrThe HVH is out due to it being a 4150 to 4500 carb application that is directions. Here is a picture of my manifold. It is kind of a pile of crap and will need some finishing to get the top to bolt on, carb studs not tapped, port entry looks to be chiseled by a cave man, etc. No big deal it will be a fun project.
[Re: Jeremiah]
#1459830
06/29/13 04:04 PM
06/29/13 04:04 PM
Jeremiah
Rogue River, OR
Ok....I think this is my solution unless I can find a 4150 top: http://www.ebay.com/itm/HVH-carb-adapter...702&vxp=mtrMost of the spacers listed 4500 manifold to 4150 carb have the holes tapped on the 4500 side and pass through holes on the 4150 side which is the opposite of what I need. Any idea if the Wilson spacers are this way was well? If not I can call on Monday and ask. edit: Wilson does make a 4150 carb to 4500 manifold adapter...
[Re: Jeremiah]
#1459831
06/29/13 05:14 PM
06/29/13 05:14 PM
Posts: 90 North Carolina
CALSDART
North Carolina
Does anyone know anyone that has an Indy Tunnel Ram for a low deck for sale
Calvin Thompson
[Re: Cab_Burge]
#1459833
06/29/13 05:27 PM
06/29/13 05:27 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
[Re: CALSDART]
#1459836
06/29/13 06:18 PM
06/29/13 06:18 PM
Jeremiah
Rogue River, OR
I looked for a used one for about six months. They are not all that common it seems. For not much more than a used one like mine you can call Bob George Racing and get a new one. I think the price is generally $150 more for brand new and you won't have to deal with the issues I am. By the time it is all said and done I'll have at least $150 in spacers to run 4150 carbs. I don't think my little 511 warrants 4500 series carbs, especially because it will get some street duty.
[Re: MRMOPAR622]
#1459838
06/29/13 06:35 PM
06/29/13 06:35 PM
MRMOPAR622
Sweet Home Alabama
Mr_Cab,showed (picture)the type adapter spacers needed for intake. Also was RIGHT about opening the 4 holes up in intake to one. Mr_Cab is the man!
