Gas tank venting 1970 Super bee 440 six pack. #1459306
06/28/13 02:10 AM
06/28/13 02:10 AM
Saskatchewan, Canada
cudabin Offline OP
cudabin  Offline OP
Does anyone have a picture of how the gas tank venting is supposed to be set up on a 1970 440 six pack Super Bee ???
It has a return line from the vapor separator back to the tank, but no charcoal cannister.
Pictures??
Thanks,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: Gas tank venting 1970 Super bee 440 six pack. [Re: cudabin] #1459307
06/28/13 07:14 AM
06/28/13 07:14 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
there is no charcoal canister on a 1970 , the return line connects to the vapor separator on one end and the sending unit on the tank at the other end.
Re: Gas tank venting 1970 Super bee 440 six pack. [Re: JohnRR] #1459308
06/28/13 08:36 AM
06/28/13 08:36 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
Yeap, very straight forward.......
Troy
Houston Mopar Connection Club
Re: Gas tank venting 1970 Super bee 440 six pack. [Re: hemi68charger] #1459309
06/28/13 11:17 AM
06/28/13 11:17 AM
cudabin Offline OP
cudabin  Offline OP
Yes, I already have the vapor seperator return line hooked up as stated, but there is another tank outlet nipple that i believe gets hooked up to a vent line that runs through the trunk area???
Drawings or pictures anyone?
Thanks,
Arnie
Re: Gas tank venting 1970 Super bee 440 six pack. [Re: cudabin] #1459310
06/28/13 12:09 PM
06/28/13 12:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
there are 2 nipples up high on the tank that connect to vent lines , one line goes into and out of the trunk floor above the rear axle the other looks like the number 7 and clips to the shock crossmember , the line on the frame rail front to back connect to the fuel sending unit.
Re: Gas tank venting 1970 Super bee 440 six pack. [Re: JohnRR] #1459311
06/28/13 01:24 PM
06/28/13 01:24 PM
Houston, Tx
Houston, Tx
Is this an original California car with the Emissions package on it as is mandated for Cali-bound '70 models? Does it have N95 on the fender tag? If so, there should be a cylinder in the trunk (passenger side wheel well).....
Troy
Re: Gas tank venting 1970 Super bee 440 six pack. [Re: cudabin] #1459312
06/28/13 02:48 PM
06/28/13 02:48 PM
USA
b54406barrel Offline
USA
Tube in trunk. Can't seem to find the 3 nipple breather pic I have.
Re: Gas tank venting 1970 Super bee 440 six pack. [Re: b54406barrel] #1459313
06/28/13 02:55 PM
06/28/13 02:55 PM
USA
USA
Re: Gas tank venting 1970 Super bee 440 six pack. [Re: JohnRR] #1459314
06/29/13 01:23 AM
06/29/13 01:23 AM
cudabin Offline OP
cudabin  Offline OP
The one that you say looks like the number 7 is missing... any pictures??? The other one is already hooked to the hard line that runs through the trunk.
Cheers,
Arnie
Re: Gas tank venting 1970 Super bee 440 six pack. [Re: cudabin] #1459315
06/29/13 09:02 AM
06/29/13 09:02 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I don't have any pictures to post , it's a line that literally looks like a 7 , it's about 6 inches of line , small piece of rubber line that connects it to the tank.
edit , I did what seems to be lost on many ... google tab at the top of the page , took me less than a minute to find the picture in another thread ...
Re: Gas tank venting 1970 Super bee 440 six pack. [Re: JohnRR] #1459316
06/29/13 01:26 PM
06/29/13 01:26 PM
Mcgregor, Ia
493RT Offline
493RT  Offline
Mcgregor, Ia
This might help, not sure what year its from..
Re: Gas tank venting 1970 Super bee 440 six pack. [Re: 493RT] #1459317
07/01/13 07:10 PM
07/01/13 07:10 PM
cudabin Offline OP
cudabin  Offline OP
Does anybody sella repo of that 7 line???
Cheers,
Arnie
Re: Gas tank venting 1970 Super bee 440 six pack. [Re: cudabin] #1459318
07/02/13 09:54 AM
07/02/13 09:54 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Cheers,
Arnie
yes , any compnay that sells repop lines , pick one ...
Re: Gas tank venting 1970 Super bee 440 six pack. [Re: JohnRR] #1459319
07/05/13 11:13 AM
07/05/13 11:13 AM
Kingsburg Calif.
Quikshft Offline
Quikshft  Offline
Kingsburg Calif.
A couple more pictures related to the topic.
Re: Gas tank venting 1970 Super bee 440 six pack. [Re: Quikshft] #1459320
07/05/13 11:15 AM
07/05/13 11:15 AM
Kingsburg Calif.
Quikshft Offline
Quikshft  Offline
Kingsburg Calif.
nudder one...
Re: Gas tank venting 1970 Super bee 440 six pack. [Re: Quikshft] #1459321
07/05/13 11:16 AM
07/05/13 11:16 AM
Kingsburg Calif.
Quikshft Offline
Quikshft  Offline
Kingsburg Calif.
Last..
Re: Gas tank venting 1970 Super bee 440 six pack. [Re: Quikshft] #1459322
07/12/13 01:27 AM
07/12/13 01:27 AM
cudabin Offline OP
cudabin  Offline OP
Anyone have the measurements of the "7" shaped line? everyone sells the 2 vent lines as a pair and I only need the "7"...
I could bend one up pretty quick...
Thanks,
Arnie
