E-body doors: restoration. #1458378
06/26/13 08:46 AM
06/26/13 08:46 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang.
Can I get some pictures posted of the inside of E-body doors with either the plastic shield installed or whatever form of sound deadening you may have done? Of course, this is without the door panel installed. I want to wrap up these doors pretty soon on my friend's '71 Challenger......
Thanks...
Troy
Houston Mopar Connection Club
Re: E-body doors [Re: hemi68charger] #1458379
06/26/13 03:10 PM
06/26/13 03:10 PM
Bloomington, IN
HoosierTA Offline
HoosierTA  Offline
Bloomington, IN
no pics, but I just used some generic clear plastic sheeting that was thinker than the original. I suspect its more for dust control, rather than sound deadening.
'70 Challenger R/T 383
'16 Hemi Durango SSV (work vehicle)
'15 Ram Police SSV
Re: E-body doors [Re: HoosierTA] #1458380
06/26/13 07:59 PM
06/26/13 07:59 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
I belive it was intended to be a moisture barrier.The plastic had sealer along the sides and bottom.
Re: E-body doors [Re: hemi68charger] #1458381
06/26/13 11:21 PM
06/26/13 11:21 PM
Houston, Tx
Houston, Tx
No one has pictures of their doors without the interior door panels off?
I can make the plastic barrier, but being that I'm Mr. Anal-2-a-certain-degree, I want it as close as possible. The original plastic barrier was taken off by my friend 8 years ago........
Troy
Re: E-body doors [Re: hemi68charger] #1458382
06/26/13 11:29 PM
06/26/13 11:29 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I have no pictures but I put a piece of dynamat over the whole door and heated it to stick it down. It sounds so much better and seals out the dirt and water, been on there since 1990.
Re: E-body doors [Re: hemi68charger] #1458383
06/27/13 09:23 AM
06/27/13 09:23 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Most of these car have been pulled apart many years ago and that plastic disappeared then, including this 74 that I took apart.
They used a dum-dum stuff like electricians use to plug holes to hold it on, I think?
I did find this photo when I took my car apart, it the rear, not the door. I do have like 6 doors in storage and I'm pretty sure a couple of them still have the dum dum on them the help decide where the plastic went. I'll try to get some pictures here soon.
Re: E-body doors [Re: Challenger 1] #1458384
06/27/13 10:47 AM
06/27/13 10:47 AM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Strip caulk was used around the perimeter, primarily as a moisture barrier. The caulk can be had from any paint or body supply store. I think I have used 3M brand. Good stuff.
Re: E-body doors [Re: 469runner] #1458385
06/27/13 11:41 AM
06/27/13 11:41 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
PCG makes a die cut kit.
Re: E-body doors [Re: 70440+6bbl] #1458386
06/27/13 12:46 PM
06/27/13 12:46 PM
Houston, Tx
Houston, Tx
Thanks everyone... I do appreciate the teaching...... I'm an E-body apprentice......
Troy
Re: E-body doors [Re: HoosierTA] #1458387
06/29/13 11:37 AM
06/29/13 11:37 AM
Houston, Tx
Houston, Tx
OK, the '71 Challenger doors continue...
1. Where do the two retaining clips that hold the mirror remote adjustment cable secure themselves. Looks like there's on obvious place, one of the three holes in the forward structure of the inner door.
Troy
Re: E-body doors [Re: hemi68charger] #1458388
06/29/13 11:37 AM
06/29/13 11:37 AM
Houston, Tx
Houston, Tx
Can you get the felt guides and stop brackets new or reproduction?
Troy
Re: E-body doors [Re: hemi68charger] #1458389
06/29/13 11:38 AM
06/29/13 11:38 AM
Houston, Tx
Houston, Tx
window stop bracket with an apparent rubber or felt cushion... There's also a little clip attached to the inner door protection plate, what is that for?
Troy
Re: E-body doors [Re: hemi68charger] #1458390
07/01/13 08:05 AM
07/01/13 08:05 AM
CT
1932chrysler Offline
CT
That is the clip to hold the remote mirror cable
1932 Chrysler CI Sedan
1956 Pontiac Catalina Sedan
All Makes & Models Are Special
Re: E-body doors [Re: hemi68charger] #1458391
07/01/13 09:06 PM
07/01/13 09:06 PM
CT
CT
here are some photos of the routing
Re: E-body doors [Re: hemi68charger] #1458392
07/01/13 09:07 PM
07/01/13 09:07 PM
CT
CT
photo 2
Re: E-body doors [Re: 1932chrysler] #1458393
07/01/13 09:43 PM
07/01/13 09:43 PM
Houston, Tx
Houston, Tx
Wow !!! Perfect !!!
Troy
