Next change on the Duster, convertor #1456165
06/21/13 07:27 PM
06/21/13 07:27 PM
in a chair
mopartony Offline OP
in a chair
Ok guys,
I am not sure what way to jump on this so here is the next chapter of the saga....
I have a PTC convertor and a Dynamic convertor. both are 9" jobs, both are set up for a trans brake.
I am wondering if I should send one of them in and have it tuned up for my current set up or just get a new one. Cost is a factor. I am thinking a new one will be in the $7-900 range plus the ride.
Thoughts?
refresh on the car, 73 Duster, 470, 1000hp carb, 13.5 to 1, 620 ultradyne cam, 4.10 gear, 2600lbs with me on E-85. this will see both street and strip.
Re: Next change on the Duster, convertor [Re: mopartony] #1456166
06/21/13 07:46 PM
06/21/13 07:46 PM
Renton Washington
Triple Threat Offline
Renton Washington
Send one in. $250 usually to cut open, adjust and put back together.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Next change on the Duster, convertor [Re: Triple Threat] #1456167
06/22/13 05:08 PM
06/22/13 05:08 PM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
Re: Next change on the Duster, convertor [Re: loaderpro] #1456168
06/22/13 07:06 PM
06/22/13 07:06 PM
Gilbert, AZ
Aspen7695 Offline
Aspen7695  Offline
Gilbert, AZ
You can have either one brought up to the specifications you now need. I had more flash added to one of mine, but it was not cheap. I spent $600. as opposed to $950. for a new one.
Raul
Re: Next change on the Duster, convertor [Re: Aspen7695] #1456169
06/22/13 07:14 PM
06/22/13 07:14 PM
Q
Quicktree Offline
Quicktree  Offline
Q
sell them both and get an 8" if you have good suspension
