ARP main stud 340 simple question? #1455450
06/19/13 07:15 PM
06/19/13 07:15 PM
AZ - The "dry heat" state
71autoxr Offline OP
71autoxr  Offline OP
I am just putting together the bottom end of my 340. I have the ARP main stud kit for windage tray (ARP 240-5501) There are 5 studs that have the extra length for mounting the tray, but my stock tray only has 4 mounting holes. Are there other trays that have a 5th mount hole?? Is there a preferred location for this stud that isn't used for the stock tray? And last, there are eight, 6 point, deep nuts, and two, 12 point, shorter nuts. Can I assume the shorter nuts are for the 5th/main cap? (And i already know about the stud under the oil pump not fitting, needing trimming etc). Thanks
68 AMX mopars red headed stepchild
69 Dart GT Convertible 340 4 speed
71 Challenger - looks like the avatar!
Re: ARP main stud 340 simple question? [Re: 71autoxr] #1455451
06/20/13 12:44 AM
06/20/13 12:44 AM
It's been a while since I used a ARP stud kit on a SB Mopar, no way the studs would work on the # 5 main cap under the oil pump side. I don't remember if that kit had 4,5 or 6 longer studs I would work on the # 5 main first and not worry about the others until that was ready to run
Re: ARP main stud 340 simple question? [Re: 71autoxr] #1455452
06/20/13 12:50 AM
06/20/13 12:50 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Windage tray mounts go on the #2 and #4 mains...
only the 4 bolts... if you have 5 they screwed up
Re: ARP main stud 340 simple question? [Re: MR_P_BODY] #1455453
06/20/13 01:00 AM
06/20/13 01:00 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
the last arp main stud kit i bought had 5 in it too...cut the 5th one off..
Tony
70 AARCuda Vitamin C
Re: ARP main stud 340 simple question? [Re: MR_P_BODY] #1455454
06/20/13 11:43 AM
06/20/13 11:43 AM
71autoxr Offline OP
71autoxr  Offline OP
I thought the same thing when I opened the package. Thought maybe there was a different windage tray than the 4 bolt I'm used to.
"the last arp main stud kit i bought had 5 in it too...cut the 5th one off.. " Bringing out the cut off wheel today to trim the one for under the oil pump, i'll hack that extra long one too.
Thanks guys.
