70 Duster Rear disc brake upgrade. Worth the time? *DELETED* #1455206
06/19/13 03:00 AM
06/19/13 03:00 AM
Arkansas
DustMaker70 Offline OP
Arkansas
Post deleted by DustMaker70
Re: 70 Duster Rear disc brake upgrade. Worth the time? [Re: DustMaker70] #1455207
06/19/13 03:10 AM
06/19/13 03:10 AM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
The addition of discs to the rear will be merely cosmetic if you do not intend to road race the car.
Rear drums are perfectly fine for most people. The switch to rear discs for many guys is because they look better through the spokes and pad replacement is easier. The rear disc kits are not cheap. THAT money would be best spent elsewhere.
Re: 70 Duster Rear disc brake upgrade. Worth the time? [Re: Jjs72D] #1455208
06/19/13 03:16 AM
06/19/13 03:16 AM
Arkansas
Arkansas
I was leaning toward the thought that the disc in rear (unless the application called for it) would be more a cometic thing. I do not know if the car came with power brakes. What number or part of the VIN would tell me that?
Re: 70 Duster Rear disc brake upgrade. Worth the time? [Re: DustMaker70] #1455209
06/19/13 03:48 AM
06/19/13 03:48 AM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
Helped my 67 BCuda (Cordoba brakes on front) really shortened the braking distance, no locking, it just stopped, hard. After 9" drums it's a godsend.
-Daty
Re: 70 Duster Rear disc brake upgrade. Worth the time? [Re: DustMaker70] #1455210
06/19/13 02:58 PM
06/19/13 02:58 PM
Cab_Burge Online work
Cab_Burge  Online Work
If you have the stock A body 1 3/4 x10 inch rear drums now and you want to swap the axles to the bigger bolt pattern you can use the stock Mopar rear brakes,10.5x10, 3x11 and so on the other option is to take your rear brake shoes to a brake reliner and have softer linings installed I did that for my Dster, I wanted to keep the stock rear brakes for the weight savings and had fork lift linings installed on several sets of the stock brake shoes They hold on the starting line a lot better, they probally won't last 60,000 miles on the street though BTW, I may have a set or two of them left that I would let go, PM me if interested
Re: 70 Duster Rear disc brake upgrade. Worth the time? [Re: DustMaker70] #1455211
06/19/13 06:31 PM
06/19/13 06:31 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Not in VIN. On fender tag. Don't know about '70, but 72-74 code book says, for brevity, codes B02 through B11; front drums of varying sizes. Codes B22 through B37; rear drums of varying sizes. Codes B41 through B43, front discs. B51; power brakes.
Re: 70 Duster Rear disc brake upgrade. Worth the time? [Re: Daty Rogers] #1455212
06/19/13 10:40 PM
06/19/13 10:40 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
-Daty
A cinder block on a rope would be an improvement over 9" drums.
Don't be the exception.
Re: 70 Duster Rear disc brake upgrade. Worth the time? [Re: Supercuda] #1455213
06/20/13 12:28 AM
06/20/13 12:28 AM
IN
ahy Offline
ahy  Offline
IN
Unless you are doing repeated stops from high speed, rear drums will be fine. Front disks are important, rear not so much. Personally I would (and did) fix up the rear drums as needed and focus on other areas.
Re: 70 Duster Rear disc brake upgrade. Worth the time? [Re: ahy] #1455214
06/20/13 01:08 AM
06/20/13 01:08 AM
Arkansas
Arkansas
I wont be doing alot of hard stopping. I plan to have the car as more of a driver and the occasional light to light race. I appreciate all the info and thoughts. I know with the tech of todays brake system I will be ok keeping it stock with drums. I have already updated the suspension with a kit from Hotchkis. Other than that I've got everything for the motor and will be replacing the 3spd with a 4spd by the fall. Oh I did have another question. I will be running a Mopar Purple 484 cam. I was told to use only oil with zinc.....is that difficult to find or is it mostly something you would have to order?
Re: 70 Duster Rear disc brake upgrade. Worth the time? [Re: DustMaker70] #1455215
06/20/13 01:40 AM
06/20/13 01:40 AM
Bradd Penn brand oil, several others are real good also. EDIT I dont think rear discs would be cost effective if you had to buy one of the $$$ kits. I've heard people say rear discs are real good & some say not worth the effort. I have a pair of SBP rotors that were in MP cardboard packages at a swap meet for $10 ea & no clue what they were meant for but they seemed like a later 80's ? item but then there was the SBP & I want to weld brackets on an 8&3/4 housing & likely use A body calipers & reduce the end play to zero & try em just to see
Re: 70 Duster Rear disc brake upgrade. Worth the time? [Re: Supercuda] #1455216
06/20/13 02:06 AM
06/20/13 02:06 AM
Texas
Daty Rogers Offline
Daty Rogers  Offline
Texas
-Daty
That would be an improvement, I kept backing up to give me room, people kept moving in front. At that point I knew I needed brakes, went a bit overboard but that's ok, I'd rather stop faster than I can accelerate on the street. I would have rather kept it stock but it was not possible with the drivers around here. Too many nuts...
-Daty
Re: 70 Duster Rear disc brake upgrade. Worth the time? [Re: Daty Rogers] #1455217
06/20/13 09:21 AM
06/20/13 09:21 AM
BDW Online content
BDW  Online Content
x2, what he said.
Most do it for looks, funny thing is a 11" drum (13 diameter) fills out a 17" rim much better than a 10" disc.
Re: 70 Duster Rear disc brake upgrade. Worth the time? *DELETED* [Re: DustMaker70] #1455218
06/20/13 07:50 PM
06/20/13 07:50 PM
Puttin' on the foil in Charles...
not_a_charger Online mad
Mr. Big Shot Moparts Moderator
not_a_charger  Online Mad
Good job expending the effort to accomplish nothing. The post is still here.
Earning every penny of that moderator paycheck.
DBAP
Re: 70 Duster Rear disc brake upgrade. Worth the time? *DELETED* [Re: not_a_charger] #1455219
06/20/13 09:31 PM
06/20/13 09:31 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Even with the delete I'll toss my My 68 Barracuda has 11.75" front disk and 11" drums. I'm going to get a set of Dr Diffs 11 rear disks. The drums are super heavy and don't modulate anywhere as well as disks. The drums will last longer with a much larger wear surface and on a perfect surface will stop just as well. But in the real world when the brakes get hot or wet, you are far better off with disks.
Re: 70 Duster Rear disc brake upgrade. Worth the time? *DELETED* [Re: Skeptic] #1455220
06/20/13 09:45 PM
06/20/13 09:45 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I seriously doubt you can drive a car hard enough on the street for REAR drum brake modulation to be an issue.
Re: 70 Duster Rear disc brake upgrade. Worth the time? [Re: DustMaker70] #1455221
06/21/13 12:23 AM
06/21/13 12:23 AM
IN
ahy Offline
ahy  Offline
IN
I run Shell Rotella T diesel engine oil which has enough zinc for a flat tappet cam. Available at Walmart or an auto parts store. Brad Penn and zinc additives to standard car oil are another option.
Re: 70 Duster Rear disc brake upgrade. Worth the time? *DELETED* [Re: not_a_charger] #1455222
06/21/13 01:07 AM
06/21/13 01:07 AM
Arkansas
Arkansas
Give a new guy a break. The delete was not intentional.
Re: 70 Duster Rear disc brake upgrade. Worth the time? *DELETED* [Re: DustMaker70] #1455223
06/21/13 01:14 AM
06/21/13 01:14 AM
I'm on your side. If anyone here gets out of line just go upside their head & they'll leave you alone. Welcome aboard & fasten your seat belt. You have just joined the worlds' premier Mopar site & the guys here are sharp beyond belief
Re: 70 Duster Rear disc brake upgrade. Worth the time? *DELETED* [Re: Supercuda] #1455224
06/21/13 10:05 AM
06/21/13 10:05 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
I wasn't talking out my _ _ _ . I've driven it, gotten the rears locked up, they DONT want to unlock.
Re: 70 Duster Rear disc brake upgrade. Worth the time? *DELETED* [Re: DustMaker70] #1455225
06/21/13 10:08 AM
06/21/13 10:08 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Fair enough, there has been a rash of people coming on, asking a question and deleting it right after getting an answer. It's annoying and counterproductive.
