Page 4 of 4 1 2 3 4
Re: Eldebrock RPM's vs. 440 Source Stealth heads [Re: ] #1455107
06/20/13 10:42 PM
06/20/13 10:42 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
i used 440 source heads in my dakota,edelbrocks would not fit under power brake booster.had machine shop check them out guides etc checked out good.wether made in china or japan there is a place for these heads mentioned earlier stock height,stock look, straight plugs.
Re: Eldebrock RPM's vs. 440 Source Stealth heads [Re: ] #1455108
06/21/13 12:03 AM
06/21/13 12:03 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
What's wrong with Joe Dirt? .
His cars are cooler than yours.
Re: Eldebrock RPM's vs. 440 Source Stealth heads [Re: viperblue72] #1455109
06/21/13 12:37 AM
06/21/13 12:37 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I dont understand the Question?
Id say if your only looking for a single head replacement ,by the el cheapo newer model stealth to match your other stealth head.
Now if you want a total switch over of heads, different story.
Do you have a "Joe Dirt" Budget or a "Donald Trump" Budget.
Joe Dirt Donald Trump
Re: Eldebrock RPM's vs. 440 Source Stealth heads [Re: Sport440] #1455110
06/23/13 12:25 AM
06/23/13 12:25 AM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
Desision made. Edelbrocks will be here monday. After everything is added up, the Edelbrocks were less than $400 more than Stealths. Thanks for all the replys guys.
Brian Dunnigan
Re: Eldebrock RPM's vs. 440 Source Stealth heads [Re: Sport440] #1455111
06/23/13 12:37 AM
06/23/13 12:37 AM
Mooresburg, Tn
Mooresburg, Tn
Budget? Are you kidding me? I'm a drag racer, there is no budget. But there is my wife...
Re: Eldebrock RPM's vs. 440 Source Stealth heads [Re: '72CudaRacer] #1455112
06/23/13 12:41 AM
06/23/13 12:41 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Brian Dunnigan
Nice....
If you can't handle the truth, you're living a lie.......
Re: Eldebrock RPM's vs. 440 Source Stealth heads [Re: '72CudaRacer] #1455113
06/23/13 05:21 AM
06/23/13 05:21 AM
tboomer Online work
tboomer  Online Work
Congrats,Brian!! I am sure you will be happy with them!!
Re: Eldebrock RPM's vs. 440 Source Stealth heads [Re: '72CudaRacer] #1455114
06/23/13 01:19 PM
06/23/13 01:19 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
You will like the eddy's
Re: Eldebrock RPM's vs. 440 Source Stealth heads [Re: Dodgem] #1455115
06/23/13 01:26 PM
06/23/13 01:26 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
You did the right thing !
Re: Eldebrock RPM's vs. 440 Source Stealth heads [Re: VernMotor] #1455116
06/26/13 02:58 AM
06/26/13 02:58 AM
Pittsburgh, PA
bobdog106 Offline
bobdog106  Offline
Pittsburgh, PA
I have my closed chambers Eddy's that were cnc'd by Modern on my street car into the 9's. They have worked great for several years with no issues.
Page 4 of 4 1 2 3 4
