New lifters question #1454620
06/17/13 10:09 PM
06/17/13 10:09 PM
S.W. Pennsylvania
markrr Offline OP
markrr  Offline OP
S.W. Pennsylvania
Is it OK to install new lifters onto a used camshaft or do lifters and cam have to be replaced together?
Re: New lifters question [Re: markrr] #1454621
06/17/13 10:18 PM
06/17/13 10:18 PM
Sturgis S.D.
tripleblackcuda Offline
Sturgis S.D.
You can replace the lifters and not the camshaft. I would use a bottle of zinc additive in the oil to help break the lifter surface in a little bit. Use assembly lube on the face (bottom) of the lifter for lubrication on the first start-up.
Re: New lifters question [Re: markrr] #1454622
06/18/13 12:25 AM
06/18/13 12:25 AM
Cab_Burge Online work
Cab_Burge  Online Work
Break in the new lifters just like you would a new cam and lifters
Re: New lifters question [Re: Cab_Burge] #1454623
06/18/13 12:39 AM
06/18/13 12:39 AM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
The rules I remember are:
New cam? New lifters.
Used cam? NEW lifters OR the exact same lifters from the exact same holes from that same used cam.
This is for NON roller type cams and lifters, of course.
Re: New lifters question [Re: Jjs72D] #1454624
06/18/13 09:29 AM
06/18/13 09:29 AM
S.W. Pennsylvania
markrr Offline OP
markrr  Offline OP
S.W. Pennsylvania
Thanks everyone. These are hydraulic flat lifters that I want to replace onto a used cam. So, when I replace them I need to use assembly lube on the lifters and then run the engine for 20 minutes at the specified RPM the same as when replacing a cam?
Re: New lifters question [Re: markrr] #1454625
06/19/13 12:33 AM
06/19/13 12:33 AM
you got it, I like to use at least twenty minutes, longer time above 1500 RPM can't hurt in any way
Re: New lifters question [Re: Cab_Burge] #1454626
06/19/13 10:09 AM
06/19/13 10:09 AM
I'd goose the throttle multiple times during that period. Helps the lifters rotate (which is critical) & better splashes oil up on the cam
