ETAX relay...what does it do? Tech help please!
#1452832
06/14/13 02:22 PM
06/14/13 02:22 PM
Posts: 1,665 Milwaukee, WI
Prince_Valiant
Milwaukee, WI
What does the ETAX relay control?
Why would it being clicking with no key in the ignition?
Likewise, why would the ASD (automatic shutdown relay) also be clicking w/ the key out of the ignition? I pulled the relays involved (ASD first, ETAX kept clicking, then pulled it...)
This is a 2007 Chrysler Aspen, 5.7 hemi, 4WD. There was a check engine light for a bad EGR valve...replacing it right now.
Put the relays back in and unplugged the battery for a bit (after charging it...I figured the battery was likely drained before I let the dogs out and heard the clicking), car started right up.
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph 1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD) 1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD) 1989 Shelby CSX #500/500
Re: ETAX relay...what does it do? Tech help please!
[Re: Prince_Valiant]
#1452833
06/14/13 08:19 PM
06/14/13 08:19 PM
Posts: 311 Mass. USA#1
hemi70
Mass. USA#1
ETAX relay is controled by the TCM and supplies power to the transmission solinoid pack. Clicking relays is most often caused by low battery voltage. Low volts can also make gauges bounce, wipers jump, chime sound and all kinds of freaky stuff. Gary.
[Re: hemi70]
#1452834
06/14/13 09:18 PM
06/14/13 09:18 PM
Prince_Valiant
Milwaukee, WI
You seem to be right Good sir!
Put a new battery today, and many little gremlins (weird window operation, mysterious shifts, inconsistent throttle hesitations, egr throwing codes, etc) have also cleared up.
thank you much for the knowledge of what was going on
