Re: float bowl level
[Re: Clanton]
#1450101
06/09/13 07:07 PM
06/09/13 07:07 PM
Posts: 252 St.Louis, Mo.
mokid
St.Louis, Mo.
Make sure your power valve does not leak.I had 2gaskets by mistake and it would run dry.
We run blank power valves
[Re: rowin4]
#1450102
06/09/13 07:11 PM
06/09/13 07:11 PM
mokid
St.Louis, Mo.
What is your fuel pressure? For float setting I just set it so the gas is just at the bottom of the hole, not running out. Also you could have fuel coming out of the vent tube causing it to flood out on sudden stop after the burn out. A fix for that is to use a piece of rubber hose raised up front to back with a air notch at the top for vent, I've also seen guy's use 90 degree spark plug boots.
6 1/2 like I said I can turn pump on bowl fills up turn pump off and it drains back.
[Re: mokid]
#1450103
06/09/13 07:12 PM
06/09/13 07:12 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I do also and it was the gasket causing the leak so what I am saying is check the gasket.
[Re: mokid]
#1450105
06/09/13 07:24 PM
06/09/13 07:24 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I would say its the PV plug gasket also... its right near the bottom so if its leaking it would leak MOST of the bowl empty
