Transmission Pans...Yeah, I know.
#1449060
06/07/13 10:42 PM
06/07/13 10:42 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
God help me. I know, I know. I've beat this horse to death. This ain't knew to me. I've changed transmission pans many times working at my uncle's gas station as a kid and on my own cars over the years. But, I cannot get this TCI aluminum pan to seal even with the Mopar gasket!!! With each gasket it leaks in a different place. It's not the transmission, it's dry above the pan. I've checked very closely. The pan is flat, no warps.
My question: What type of trans pan came on the 1970/71 440 six pak cars. Didn't they have a torque converter that stalled around 2,300 RPM? How did they come from the factory. Did they have deeper pans and/or transmission coolers?
The reason I ask is that I'm concerned hurting the transmission in my Coronet if I run a deep steel pan without a cooler. The torque converter I run is a custom, tight, heavy duty 12" 'verter that will flash to 2,500 RPM from a standing start. At cruise it seems very efficient like a stocker. At light throttle it moves very quickly from a stop. Will I be taking a chance running a deep steel (2 extra quarts) transmission pan without a transmission cooler?
Re: Transmission Pans...Yeah, I know.
[Re: Junky]
#1449064
06/08/13 12:24 AM
06/08/13 12:24 AM
Posts: 30,632 Florida STAYcation
IcorkSOAK
Financed his waterbed
Florida STAYcation
DIFF places with DIFF gaskets ?.... did you baby-powder these areas ?
[Re: IcorkSOAK]
#1449066
06/08/13 12:35 AM
06/08/13 12:35 AM
Junky
Wherever I am.
Doc, I never know if you're pulling my chain or you're serious.
[Re: Junky]
#1449068
06/08/13 12:47 AM
06/08/13 12:47 AM
RapidRobert
Might try a tube of "the right stuff" instead of a gasket. Make sure you let it setup thick (which dont take long) before adding the pan. It'll take a chisel to get the pan off the next time but it wont leak. I'm assuming that it is the pan rather than one of the other notorious locations that drip down & fool ya on their location
[Re: Junky]
#1449069
06/08/13 12:51 AM
06/08/13 12:51 AM
IcorkSOAK
Florida STAYcation
JUNKster .... WHEN have I ever pulled-yurr-chain ?...
IF IT was leaking in the same areas(below the gasket)... it could be a porous alum casting ....
[Re: Junky]
#1449071
06/08/13 12:57 AM
06/08/13 12:57 AM
Posts: 75,282 A gulag near you.
JohnRR
A gulag near you.
The 6 pack and hemi cars ran the same depth pan as any 727 behind any engine it was offered behind including the lowly slant 6 .
Have you tried a fiber gasket ?
Most every gasket but a cork gasket. Don't know what you mean by "fiber".
It's not a cork gasket , it's a 1/16ish thick hard gasket , I use it on my ram trans with mag hytech alum pan , seals great and I have reused it. I buy them at transtar , not sure if it's something you can get at a parts store , try a local trans shop .
[Re: ireland383]
#1449075
06/08/13 12:36 PM
06/08/13 12:36 PM
Junky
Wherever I am.
I'm running the steel deep pan with a 2400/2600 stall with no heat problems.
Thank you for the info.
[Re: Jjs72D]
#1449076
06/08/13 11:11 PM
06/08/13 11:11 PM
Posts: 637 SoMd, USA
135sohc
SoMd, USA
My brother-in-laws 07 Ram had Mopar RTV as a sealant. NO gasket and no leaks.
The RFE's are made for RTV, nice wide, flat flange for that junk to squish around and seal. Works great until your the one cussing at it trying to get the pan off and scrape all that garbage off to reseal it.
[Re: slantzilla]
#1449079
06/09/13 01:24 PM
06/09/13 01:24 PM
Posts: 404 Central New York
bfury
Central New York
Forget about gaskets. Go to a mopar parts department and get a tube of ATF RTV. Use it liberally toward the outside edge of the pan. Let sit overnight and you will be leak free from the pan. I mouted a very deoop B&M pan to an early PB 727. The trans pan rail was not flat and it sealed. I love it. Oh by the way, I was using the new Mopar reusable silicone gasket, it leaked.
No Stock
