Transmission Pans...Yeah, I know. #1449060
06/07/13 10:42 PM
06/07/13 10:42 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
God help me. I know, I know. I've beat this horse to death. This ain't knew to me. I've changed transmission pans many times working at my uncle's gas station as a kid and on my own cars over the years. But, I cannot get this TCI aluminum pan to seal even with the Mopar gasket!!! With each gasket it leaks in a different place. It's not the transmission, it's dry above the pan. I've checked very closely. The pan is flat, no warps.
My question: What type of trans pan came on the 1970/71 440 six pak cars. Didn't they have a torque converter that stalled around 2,300 RPM? How did they come from the factory. Did they have deeper pans and/or transmission coolers?
The reason I ask is that I'm concerned hurting the transmission in my Coronet if I run a deep steel pan without a cooler. The torque converter I run is a custom, tight, heavy duty 12" 'verter that will flash to 2,500 RPM from a standing start. At cruise it seems very efficient like a stocker. At light throttle it moves very quickly from a stop. Will I be taking a chance running a deep steel (2 extra quarts) transmission pan without a transmission cooler?
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Transmission Pans...Yeah, I know. [Re: Junky] #1449061
06/07/13 10:58 PM
06/07/13 10:58 PM
Park Forest, IL
slantzilla Offline
Happy Birthday slantzilla  Offline
Park Forest, IL
No.
Re: Transmission Pans...Yeah, I know. [Re: Junky] #1449062
06/07/13 11:48 PM
06/07/13 11:48 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Get a second opinion.
Re: Transmission Pans...Yeah, I know. [Re: Junky] #1449063
06/08/13 12:01 AM
06/08/13 12:01 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The 6 pack and hemi cars ran the same depth pan as any 727 behind any engine it was offered behind including the lowly slant 6 .
Have you tried a fiber gasket ?
Re: Transmission Pans...Yeah, I know. [Re: Junky] #1449064
06/08/13 12:24 AM
06/08/13 12:24 AM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
DIFF places with DIFF gaskets ?.... did you baby-powder these areas ?
Re: Transmission Pans...Yeah, I know. [Re: JohnRR] #1449065
06/08/13 12:34 AM
06/08/13 12:34 AM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Most every gasket but a cork gasket. Don't know what you mean by "fiber".
Re: Transmission Pans...Yeah, I know. [Re: dOOc] #1449066
06/08/13 12:35 AM
06/08/13 12:35 AM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Doc, I never know if you're pulling my chain or you're serious.
Re: Transmission Pans...Yeah, I know. [Re: slantzilla] #1449067
06/08/13 12:36 AM
06/08/13 12:36 AM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
No.
That's good enough for me. Thanks.
Re: Transmission Pans...Yeah, I know. [Re: Junky] #1449068
06/08/13 12:47 AM
06/08/13 12:47 AM
Might try a tube of "the right stuff" instead of a gasket. Make sure you let it setup thick (which dont take long) before adding the pan. It'll take a chisel to get the pan off the next time but it wont leak. I'm assuming that it is the pan rather than one of the other notorious locations that drip down & fool ya on their location
Re: Transmission Pans...Yeah, I know. [Re: Junky] #1449069
06/08/13 12:51 AM
06/08/13 12:51 AM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
JUNKster .... WHEN have I ever pulled-yurr-chain ?...
IF IT was leaking in the same areas(below the gasket)... it could be a porous alum casting ....
Re: Transmission Pans...Yeah, I know. [Re: dOOc] #1449070
06/08/13 12:57 AM
06/08/13 12:57 AM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Sorry, I know better. You're a great guy.
I'm so sick of this pan I just ordered a deep non chrome steel pan from Mancini. I now have new wall art for the garage. Piece of s...
Re: Transmission Pans...Yeah, I know. [Re: Junky] #1449071
06/08/13 12:57 AM
06/08/13 12:57 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's not a cork gasket , it's a 1/16ish thick hard gasket , I use it on my ram trans with mag hytech alum pan , seals great and I have reused it. I buy them at transtar , not sure if it's something you can get at a parts store , try a local trans shop .
Re: Transmission Pans...Yeah, I know. [Re: JohnRR] #1449072
06/08/13 02:08 AM
06/08/13 02:08 AM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
My brother-in-laws 07 Ram had Mopar RTV as a sealant. NO gasket and no leaks.
Re: Transmission Pans...Yeah, I know. [Re: Jjs72D] #1449073
06/08/13 07:29 AM
06/08/13 07:29 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
No gasket permatex the right stuff
Re: Transmission Pans...Yeah, I know. [Re: Junky] #1449074
06/08/13 08:38 AM
06/08/13 08:38 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
I'm running the steel deep pan with a 2400/2600 stall with no heat problems.
Re: Transmission Pans...Yeah, I know. [Re: ireland383] #1449075
06/08/13 12:36 PM
06/08/13 12:36 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Thank you for the info.
Re: Transmission Pans...Yeah, I know. [Re: Jjs72D] #1449076
06/08/13 11:11 PM
06/08/13 11:11 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
The RFE's are made for RTV, nice wide, flat flange for that junk to squish around and seal. Works great until your the one cussing at it trying to get the pan off and scrape all that garbage off to reseal it.
Re: Transmission Pans...Yeah, I know. [Re: Junky] #1449077
06/08/13 11:39 PM
06/08/13 11:39 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
I run a steel pan no cooler 2800 stall convertor with no problems. I have good luck useing standard gasket with indian head sealer. Put the pan on wait over night to add fluid. Allways worked out well for me. I think any sealer would do the job i think the trick is letting it set up over night before adding fluid.
Re: Transmission Pans...Yeah, I know. [Re: Dougsmopars] #1449078
06/09/13 04:04 AM
06/09/13 04:04 AM
Park Forest, IL
slantzilla Offline
Park Forest, IL
Mopar makes a very nice re-usable trans pan gasket. They are a little spendy, but they work very well.
Re: Transmission Pans...Yeah, I know. [Re: slantzilla] #1449079
06/09/13 01:24 PM
06/09/13 01:24 PM
Central New York
bfury Offline
bfury  Offline
Central New York
Forget about gaskets. Go to a mopar parts department and get a tube of ATF RTV. Use it liberally toward the outside edge of the pan. Let sit overnight and you will be leak free from the pan. I mouted a very deoop B&M pan to an early PB 727. The trans pan rail was not flat and it sealed. I love it. Oh by the way, I was using the new Mopar reusable silicone gasket, it leaked.
No Stock
