Re: CV joint at front of driveshaft
[Re: 71 Charger R/T]
#1448399
06/06/13 12:53 PM
06/06/13 12:53 PM
Andrewh
[Re: 65fury]
#1448400
06/06/13 04:17 PM
06/06/13 04:17 PM
Posts: 22,696 Bitopia
jcc
Bitopia
The real issue is however IMO, the trunion style you have doubles as a slip joint, and just adding a flange and a u joint does not solve all your problems. S My bad, Andrews link addresses the issue, which I had to on my 62 dart
[Re: Andrewh]
#1448402
06/07/13 09:38 AM
06/07/13 09:38 AM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
My 65 B body still has the OE one.Its a 550 hp 440 4 speed.Ive broken a lot or rear joint but never a front.One option is a 66 up 4 speed and drive shaft as 65 4 speed was the last year in cars for the B&T.Rocky
Chrysler Firepower
[Re: 65fury]
#1448404
06/07/13 08:34 PM
06/07/13 08:34 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Ball and trunnion parts are not hard to find, maybe in locally, but getting one isn't. www.oldmoparts.com is another source. Ran one in my 64 300 for years with a warm 413, a stick, 4.10 gears and N50 meats. Broke the rear U joint and even ripped the ear off the 8 3/4's yoke, but never broke a B&T. My older MoPars had them as well, but a flathead 6 never stressed them.
[Re: Supercuda]
#1448405
06/07/13 10:49 PM
06/07/13 10:49 PM
Posts: 1,606 Pgh, PA
Bull1tt
Pgh, PA
Well, there are two different size B&T joints. I am working on a 64 Dodge (for a customer) that was a /6 automatic and installing a 440 with a pushbutton BB 64 transmission. There was no flange on the rear of the rebuilt supplied trans. I have a BB 64 trans that has the flange, but the orig driveshaft B&T won't fit the BB flange. However, I also have a 64 trans from an Imperial, and it has what looks like an 8 3/4 pinion yoke on it that I removed. I will get a driveshaft made with a slip yoke shaft like a truck, pretty much what the above linked article shows. Any case, here are a couple pics of that yoke, it looks just like the one the 741 rear end in the car. Has #2882284 on it and 20 HT W stamped on it also.
