install cylinder head studs #1448158
06/05/13 08:45 PM
06/05/13 08:45 PM
Bowie, Md. 20720
73Chargerdude Offline OP
Bowie, Md. 20720
What is the best way to hold the studs to tighten into the heads. How much torque should I apply. (stock 440 cast iron heads). I cannot find the number in Service Manual or Mopar engine book, and am afraid the 30 ft-lbs called out for nuts is too great because of the small contact area of stud unthreaded surface to head female threads. I do not want to rip out these 40 yr old aged threads. I intended to use Permatex Super 300 sealant. Any thoughts. Help.
Re: install cylinder head studs [Re: 73Chargerdude] #1448159
06/05/13 09:09 PM
06/05/13 09:09 PM
Double nut the end with 2 fine thread nuts & screw it in nice & snug down to the shoulder
Re: install cylinder head studs [Re: 73Chargerdude] #1448160
06/05/13 09:30 PM
06/05/13 09:30 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
They get screwed into the block hand tight, do not torque them.
If they don't have a allen in the end, then double nut them will work. There is a stud tool that grips the stud by the thread which is the right way to grip them.
web page
I've screwed together many motors with studs only. This motor is all studs, everything is held on it with a stud.
Re: install cylinder head studs [Re: Challenger 1] #1448161
06/05/13 09:56 PM
06/05/13 09:56 PM
Fort Lee, VA
BattleCruiser71 Offline
Fort Lee, VA
Permatex! I'd use fish oil and some Coors Light.
Ole' Ugly, my 1985 Gran Fury. Luke, my 39,000 mile 77 New Yorker, Darth, my 50,000 mile 60 New Yorker.
Re: install cylinder head studs [Re: Challenger 1] #1448162
06/05/13 09:57 PM
06/05/13 09:57 PM
Bowie, Md. 20720
Bowie, Md. 20720
Hand tight? I did that on install and they leaked. Surely they can take 10 ft-lbs on the double nut, How about the Super 300. I've seen others use teflon tape, but I wonder if that is right fpr these coarse threads at high temp.
Re: install cylinder head studs [Re: RapidRobert] #1448163
06/05/13 10:00 PM
06/05/13 10:00 PM
Bowie, Md. 20720
Bowie, Md. 20720
Snug? need torque. How about 10 ft-lbs, How about the permatex?
Re: install cylinder head studs [Re: 73Chargerdude] #1448164
06/05/13 10:42 PM
06/05/13 10:42 PM
AndyF Offline
AndyF  Offline
Studs go in finger tight only
Re: install cylinder head studs [Re: 73Chargerdude] #1448165
06/05/13 10:58 PM
06/05/13 10:58 PM
When the OP said 30 ft lbs I was thinking that he was inquiring about OE exhaust double end studs with the shoulder in the middle for the headers/manifolds
Re: install cylinder head studs [Re: RapidRobert] #1448166
06/06/13 10:25 AM
06/06/13 10:25 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
are you trying to put studs in with the heads still on?
the way to do it is remove the head, install the studs hand tight/snug. no real torque.
the torque on the threads comes when you put the nut on after the head is dropped onto the studs, and you torque the nut on the stud. it will pull up on the stud as you torque down on the nut, and the threads will seal. (as long as you also put some light sealant on the threads for the wet holes)
**Photobucket sucks**
Re: install cylinder head studs [Re: 73Chargerdude] #1448167
06/06/13 02:57 PM
06/06/13 02:57 PM
Cincinnati, Ohio
Cincinnati, Ohio
Here's what stud installer/remover looks like. It grips the threads and you tighten the col-let and it will remove install any stud with no damage to the stud.
Those tools in the back are stud removers only and will damage the stud.
Re: install cylinder head studs [Re: 73Chargerdude] #1448168
06/06/13 04:41 PM
06/06/13 04:41 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
what studs are you talking about , studs holding the heads to the block or the studs that hold on the exhaust manifolds ? If it's the exhaust studs you have to put a sealer of some sort on them , tightening them is not going to keep them from leaking.
Re: install cylinder head studs [Re: JohnRR] #1448169
06/06/13 05:11 PM
06/06/13 05:11 PM
Bowie, Md. 20720
Bowie, Md. 20720
Exhaust header studs.
Thank you all for reponses.
I have cleaned threads thoroughly, will tighten only to a few ft-lbs (strong hand tight) with the double nut and use the Permatex 300, wait 48 hours befor coolant refill, and hope for better seal.
Re: install cylinder head studs [Re: 73Chargerdude] #1448170
06/06/13 07:20 PM
06/06/13 07:20 PM
Cincinnati, Ohio
Cincinnati, Ohio
You should change you title of your post then.
I think exhaust studs should be snugged in or even tightened with plenty of sealer, maybe a hi temp sealer?,IMO.
Head studs are a different story...
